Deck scuppers - Page 2 - SailNet Community
 3Likes
post #11 of 14 Old 05-07-2018
Re: Deck scuppers
Got it.
paulinnanaimo is online now
post #12 of 14 Old 05-07-2018
Re: Deck scuppers
Originally Posted by capta View Post
Our Pearson 530 came with 4, 1.5" deck scuppers that drain through 4'+ long hoses to 4 thruhull/seacocks at the waterline. This seems nonsensical to me. I'm thinking of just putting in a 90 degree fitting to a thruhull and running them directly overboard a few inches below the deck. We never bury the rail and even if we did I can't imagine it would matter for the few seconds the rail might be under water.
Can anyone give me a good reason why I shouldn't do this?
Can you place the hoses at an angle? I mean, they should be lower than horizontal to drain with the boat level.
Is the hose path clear to go from straight down to higher up?
SVTatia is offline
post #13 of 14 Old 05-09-2018 Thread Starter
Master Mariner
capta's Avatar
Re: Deck scuppers
Originally Posted by paulinnanaimo View Post
That would probably do the trick if you don't mind the unorthodox appearance.
But I have to ask because I have always envied the type of scuppers that you have now, why are they nonsensical?
For several of the seacocks you must literally take the bottom out of hanging lockers and the like.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #14 of 14 Old 05-09-2018 Thread Starter
Master Mariner
capta's Avatar
Re: Deck scuppers
capta is online now
clearing scuppers kbbarton Pacific Seacraft 7 05-30-2016 06:07 PM
Installing tapered scuppers? SanDiegoChip Gear & Maintenance 12 08-28-2014 12:27 PM
Advice on scuppers & drains pbpg Gear & Maintenance 25 02-14-2012 07:53 PM
scuppers 9407 Gear & Maintenance 11 05-22-2005 07:56 PM
Freezing Scuppers Quickstep192 Gear & Maintenance 3 04-02-2001 02:56 PM
