Main Sail Plastic snap shackle removal - SailNet Community
 9Likes
post #1 of 17 Old 05-10-2018 Thread Starter
I need to replace my main (dirty so replacing with cleaner sail), but, with quite a bit of force using a flat blade screw driver they won't pop loose. I feel any more pressure and I'll break them. Any suggestions?
Thanks
smitrock63 is offline
post #2 of 17 Old 05-10-2018
JimsCAL's Avatar
Re: Main Sail Plastic snap shackle removal
Are you talking about the slides/slugs? Plastic snap shackle doesn't seem to make sense.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #3 of 17 Old 05-10-2018 Thread Starter
I think they are called "plastic or nylon snap shackles". They attach the sail to the slugs that run in the mast.
post #4 of 17 Old 05-10-2018
Spray them with penetrating oil or whatever you've got handy and force the situation. If you break one or a few they don't cost a dollar apiece to replace.
smitrock63 likes this.
drew1711 is offline
The Following User Says Thank You to drew1711 For This Useful Post:
smitrock63 (05-10-2018)
post #5 of 17 Old 05-10-2018
BTW, it occurs that sometimes those things are designed not to open up again. If this is the case, get out your hacksaw and go to Sailrite for replacements.
MarkofSeaLife and smitrock63 like this.
drew1711 is offline
post #6 of 17 Old 05-10-2018
celenoglu's Avatar
Remove the plastics including the cars. Use new ones for your clean sail. It will be much easier in case you need the old sail again.
celenoglu is online now
post #7 of 17 Old 05-10-2018
JimsCAL's Avatar
Gotcha. Sailrite lists them as "snap-in shackles". When I hear snap shackle I think of the stainless things that are commonly used to attach a halyard to the head of a sail.
Those things can be hard to open as they are not made for routine opening and closing. Might be worth it just go with new ones as has been suggested.
S/V First Tracks
1985 Cal 33-2
post #8 of 17 Old 05-10-2018
Sailnet Vendor
jblumhorst's Avatar
Location: San Francisco Bay area and West Coast by trailer
Dock
Thanks
Do they look like this?
or this?
We call them "bash-ons" at our loft. They are made by Bainbridge, part numbers A021, A022, A023, or A024
If they are like these, they can be opened carefully with a large flat head screw driver. I have done it many times. If you cut or gouge the shackle, I recommend that you discard it.
I'm a sailmaker and I've seen very old nylon shackles and slides break due to UV degredation. It's hard to know how old the ones that broke were, maybe 15 years old, maybe newer, maybe older.
If they are older than 10 years (less if you live in a high UV location), I would recommend you replace them, along with the slides/slugs.
The nylon gets brittle with age. They eventually break, especially the ones at the top of the luff. If you can break them when you open them, they are too brittle.
Judy B
Sailmaker
Judy B
San Francisco Bay and Delta
F24 Trimaran
jblumhorst is offline
post #9 of 17 Old 05-11-2018
Grasshopper
JiffyLube's Avatar
or this?
Judy B
Sailmaker
Judy B,
I have a question for you. All the shackles and slides on my boat are the nylon types, and I've replaced them all but three. These three are made out of some kind of metal, and they're located at the aft end of the mainsail foot near the clew. One is corroded into the boom, and I've tried several things to get it loose, but I've been unsuccessful so far. Got any ideas how I can get it loose?
JiffyLube is offline
post #10 of 17 Old 05-11-2018
your best route would be to replace them all:
There we were, coming around the eastern point of Peaks Island. Winds were in the 15 knot range, gusting to 25. Earlier, I asked my lovely bride to trim the jig. The wind gusted and POP! My winch landed in my lap on the over end of the cockpit. Back at Peaks, I looked up the check my widex and saw a shacke just above the boom snap. Then the next one . . . and the next . . and the next . next. next nextnextnextnextxtxtxt. Yes, my sail unzipped from the mast in anout four seconds. So, I replaced them all. If you don't have a chandlery near by consider using Sailrite.com. Those guys and gals are great. I've bought many hundreds of dollars in stuff from them, including . . . . a mainsail kit and all new slugs and shackles. Also a sail pack parts and sundry items. Prices are good, shipping is reasonable, service is awesome. Abd the instructional videos are to die for!
Don
Portland, ME
DonScribner is offline
'84 H31 Main Hatch Slide Removal SloopJonB Gear & Maintenance 2 10-12-2015 09:40 PM
Plastic mast track removal?? TIKI TIME Gear & Maintenance 4 07-30-2013 07:22 PM
Sail slide / slug shackle size? MITBeta Gear & Maintenance 3 05-09-2012 05:46 PM
Plastic paint for tired looking plastic parts Goodnewsboy Gear & Maintenance 3 01-01-2007 07:15 AM
