Smoking Outboard - SailNet Community
post #1 of 13 Old 06-25-2018 Thread Starter
mstern's Avatar
Smoking Outboard
I know that smoking is bad for me, but what does it mean when my outboard smokes?
The skinny: I have a brand-spankin' new 8 HP four stroke Tohatsu on my Oday 23. The other night, I noticed that some smoke was coming from the unit while it was running. I couldn't see exactly where it was coming from as it was clearly coming out of the back somewhere.
Not a lot of smoke, but enough to notice. The amount of smoke increased (albeit only slightly) when I throttled up to go faster, and decreased when I throttled down. This particular model of engine has a "warning light" that lights up when things are not optimal, and it was dark. The engine otherwise sounded and ran fine.
Before I go through the rigamarole of removing it and taking it back to the dealer for service, I thought I'd ask the collective here for your wisdom. Thanks.
mstern is online now
post #2 of 13 Old 06-25-2018
Re: Smoking Outboard
What color is the smoke?
drew1711 is offline
post #3 of 13 Old 06-25-2018
Master Mariner
capta's Avatar
What color smoke? Smoke or steam; how cold was it? Is it at all possible someone added oil to the gas?
Why take a chance, if it's still under warranty? Take it to the dealer.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #4 of 13 Old 06-25-2018 Thread Starter
mstern's Avatar
smoke was white. It was about 72 degrees out, and no, there was no oil in the gas.
post #5 of 13 Old 06-25-2018
That's steam and should not be present. There's either water in the head or a leak near the manifold (hopefully, the latter). Take it back to the dealer right away.
drew1711 is offline
post #6 of 13 Old 06-25-2018
kaisersling's Avatar
Dock
Was water coming out of the tell tale?
kaisersling is offline
post #7 of 13 Old 06-25-2018
When you take it back to the dealer,mention the STEAM. It's their problem.
Capt Len is offline
post #8 of 13 Old 06-25-2018 Thread Starter
mstern's Avatar
Yes, like a race horse.
post #9 of 13 Old 06-25-2018
Guyfromthenorth's Avatar
Most likely steam, however see if you can smell it. Often motors are sold new with a light coating of oil on their internals to prevent corrosion while on the shelf. This light oil will burn off slowly as you use the engine, it will usually smell like burning wax or plastic.
Some youtube videos, nothing fancy
Guyfromthenorth is offline
post #10 of 13 Old 06-25-2018
If its peeing then its not clogged with seaweed and should not be steaming. No chance it was just rainwater evaporating off the hot engine or that water from following seas getting up under the engine cowling?
I am presuming its a 20" shaft engine and the ventilation plate is set about 6" below the water line.
I just bought a new engine too however the dealer ran it in for 30 minutes in his test tank and verified everything with me.
At least a phone call to the dealer would be in order to see if they want you to check anything or just have you bring it straight back. You have a 5 year warranty on that one that you probably want to keep in force. Log the date, time and person you speak with along with their instructions especially if they tell you to not worry about it and just run it until it stops smoking.
SeaStar58 is offline
Evinrude 15hp OB Motor smoking Birdface Gear & Maintenance 27 03-20-2009 06:16 PM
Yanmar smoking out rear marinesniper Gear & Maintenance 5 07-26-2008 07:05 AM
Valpo smoking ban could face tough challenge (The Times of Northwest Indiana) NewsReader News Feeds 0 09-14-2006 02:15 AM
