Outboard on or off Dinghy While Towing? - Page 2 - SailNet Community
 15Likes
post #11 of 31 Old 07-03-2018
Re: Outboard on or off Dinghy While Towing?
I used to try to figure the odds of the motor getting wet because I left it on, versus the motor getting wet and sunk because I dropped it while trying to attach or detach.
Usually "door number one" won out. But this was coastal, put-in-every-night sailing, not long sea passages.
nolatom is offline
post #12 of 31 Old 07-03-2018
On a charter around the BVIs we towed with the motor on. 10-15 knots, plenty of places to dock, charter base a couple hours away. On a charter down the windward isles we took the motor off but towed the dink. 20+ knots, nowhere to dock, charter base days away.
Of course in both cases, it wasn't our motor. In the BVIs the charter company advised us to leave the motor on. I suspect that folks who don't know what they are doing are likely to drop the motor in the water and/or on themselves.
jeremiahblatz3 is online now
post #13 of 31 Old 07-03-2018
I’m not an experienced sailor by any means, but when we were down in the BVI last week, just about every one towed their dinghies behind them with their outboards still attached. I got the impression that it was the standard practice down there.
Nephroid is offline
post #14 of 31 Old 07-04-2018 Thread Starter
Lol, been there
wingman10 is offline
post #15 of 31 Old 07-04-2018 Thread Starter
Interesting that BVI charter company recommended leaving on the dink. In this case, suspect it is more of a business consideration. Tradeoff between injury to clients, damage to the boat moving the outboard on and off everyday, potential to drop it in the drink, versus sailing considerations.
post #16 of 31 Old 07-04-2018
TQA
Bombay Explorer 44
TQA's Avatar
Some related issues.
RIBS are much less prone to flipping than soft bottom dinks.
DO you have a recovery plan IF the dink plus engine flips when you are anywhere that is not pretty sheltered. Speed will be down to a crawl. It will be a brave and foolish sailor who goes in to try and right it.
If you are expecting the insurance to payout read the small print. Most won't.
TQA is offline
post #17 of 31 Old 07-04-2018
fallard's Avatar
When I used an Avon roll-up, the 29 lb OB was on the stern pulpit. For longer (>25 mi) legs, the dink was on the foredeck, deflated.
With my current Avon RIB, the dink and 100 lb motor are towed, but this package weighs about 300 lbs total. For the 10 years Iíve towed this dink, I have never had a problemónot even shipping any significant amount of water. Of course, this is all coastal sailing with no overnight passages.
fallard is online now
post #18 of 31 Old 07-05-2018
Which Avon Rib do you have. In Avon's current rib lineup the 360 is the smallest, weighs in at 441lbs without the motor and is spec's for a 40hp min which adds an additional 211lbs so 653lbs.
https://www.avonmarine.com/rental_se...rt-360-delux/#
That adds up as a 40 hp Yamaha is around $6,300 and the Avon 360 around $16,000 so as a package were talking around $23,000. That's quite a nice dink and yes a bit heavy to handle without davits and winches.
SeaStar58 is offline
post #19 of 31 Old 07-05-2018
Learning the HARD way...
eherlihy's Avatar
If you leave the outboard bolted to the transom of an inflatable dink, you are raising the center of gravity of an air floor, slat floor or even a panel floor dink by doing so.
While the dink has inherent stability from its shape (form stability) its point of maximum stability, with an outboard motor attached, is inverted.
This would be less so with a RIB with a rigid (aluminum or fiberglass) hull, but enough of a concern that I would not do it.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #20 of 31 Old 07-05-2018
SanderO's Avatar
use this:
Garhauer Marine
LD6-1M W/34 - Stainless Steel Blocks Lifting Davit
length: width:
weight: shackle:
Tubing diameter is 1-3/4", height is 64" and arm length is 34". Comes with 5/16" X 60' line and single handed controls. Lifting capacity is 100 lbs. Includes upper support ring, and lower ball mount.
Good for most OBs up to 15hp. retail is $121. Demounts and stows easily. Takes 5 minutes to raise of lower a motor onto a dink.
pay attention... someone's life depends on it
SanderO is online now
towing a tandem kayak as dinghy xbalancex7 General Discussion (sailing related) 20 02-02-2020 02:47 PM
How to dock while towing dinghy Michigander Cruising & Liveaboard Forum 17 01-30-2020 08:32 AM
Dinghy towing gulfcoastcruiser Cruising & Liveaboard Forum 4 08-31-2010 01:59 PM
Towing a dinghy PBzeer Seamanship & Navigation 57 02-19-2007 11:22 PM
Towing hard dinghy EClaire Gear & Maintenance 3 04-24-2003 08:47 PM
