Inflatable PDF maintenance - SailNet Community
 1Likes
  • 1 Post By scott_lampe
post #1 of 10 Old 07-31-2018 Thread Starter
MacBlaze's Avatar
Inflatable PFD maintenance
I was just reading this
https://cpsboat.wordpress.com/2013/0...flatable-pfds/ and realized that while I visually inspect my inflatable (automatic/non-hydrostatic) that I've never thought of replacing the "pill" let alone doing it every few years. And does that mean I would end up with a bunch of unused CO2 cartridges since I have never seen the pill-thing sold separately.
I suppose I could just jump in the water every two years for fun and then rearm...
Gaudeamus igitur iuvenes dum sumus...
before it's too late
MacBlaze is online now
post #2 of 10 Old 07-31-2018
Re: Inflatable PDF maintenance
If you've never tried swimming with an inflatable pfd, I'd recommend you do just that to see what it's like.
Damon Gannon is offline
post #3 of 10 Old 07-31-2018
I would also suggest that you try it once. However, the rearm pin and pill is available without the CO2.
tomandchris is offline
post #4 of 10 Old 08-01-2018
scott_lampe's Avatar
Where? I have had the same problems, asked in stores if they could sell me just the plastic pin and none would. No one at the stores had ever heard of such a thing. "Oh you have to replace the canister" they would exclaim, damn things cost half the price of the lifejacket.
Sent from my SM-N950F using Tapatalk
scott_lampe is offline
post #5 of 10 Old 08-01-2018
Check "rearm kit" at Landfallnavigation.com. I have no connection other than being a satisfied customer.
Hudsonian is online now
post #6 of 10 Old 08-01-2018
Had a look and could still only see options to buy the co2 canister and the plastic pin.
When servicing your inflatable vest you break the pin when testing but you do not have to replace the canister of gas unless it is damaged or lighter than it should be. But i can't seem to be able to purchase just the plastic pin.
MacBlaze likes this.
post #7 of 10 Old 08-01-2018 Thread Starter
MacBlaze's Avatar
Amazon for the win: https://www.amazon.com/Green-Indicat.../dp/B002O7AIZE
https://www.amazon.com/Inflatable-PF.../dp/B002O76J66
You know, as much as I "hate" amazon for its destructive trade practices, you can't help loving them.
The Following User Says Thank You to MacBlaze For This Useful Post:
scott_lampe (08-01-2018)
post #8 of 10 Old 08-01-2018
Nice work MacBlaze.[emoji3]
post #9 of 10 Old 08-02-2018
Chastened
Ajax_MD's Avatar
Damon is right. Try swimming in an inflatable PFD. It's an eye opening experience. After you try it, buy one of these:
https://www.defender.com/product.jsp...131&id=3142281
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #10 of 10 Old 08-02-2018
There are "pills" and there are "bobbins". The bobbin being the rarer more expensive design that uses paper mache wound over a spring, less likely to crumble in moist air than the "pill" type. Since that Amazon page shows bobbin packs "bought with" those indicators...just be sure the indicator is the right type.
My first PFD was made before indicators existing, so it doesn't need that nonsense. Second one, same type, has the indicator nonsense on it, and that doesn't stop me from physically looking at the pointy end of things to make sure it will work properly anyhow. Just another nuisance.
hellosailor is offline
Life and Inspection of Inflatable PDF's NCC320 Gear & Maintenance 2 05-05-2016 07:49 AM
Latitude 38 is available in .pdf n8kraft US West Coast 0 03-02-2011 12:53 PM
pdf latitudes & attitudes / seafaring GEMINIDREAMS General Discussion (sailing related) 1 02-20-2010 03:29 PM
Posting PDF? danielgoldberg SailNet FAQ 8 11-12-2009 03:57 PM
Old gear manuals, pdf form cberkholtz Gear & Maintenance 1 12-05-2008 02:22 PM
