How bad is my main sail? - SailNet Community
 16Likes
post #1 of 38 Old 08-07-2018 Thread Starter
Question How bad is my main sail?
So I am pretty certain I know the answer to this question but how worn out is this main sail? I don't have a winch to crank the halyard but not real sure this would make much difference (23 foot Spirit). I feel like I can get a reasonable shape out of the genoa but the main is always super saggy at the bottom. The outhaui also has no blocks so I would guess that would help a bit also.
The preference now seems to be for loose footed sails, would that be much of a benefit?
Thanks
tschmidty is offline
post #2 of 38 Old 08-07-2018
mbetter's Avatar
Re: How bad is my main sail?
Is that picture supposed to demonstrate something other than you don't know how to set your jib? No idea how you can possibly get a reasonable shape out of a jib without hanking it on.
mbetter is offline
post #3 of 38 Old 08-07-2018
If That's the best you can do, to give him advice, why bother responding?
To the OP.. It's difficult to tell the condition of your mainsail from the picture you posted. Maybe you can post another picture of the full main.
With Regard to the Head Sail. It looks like you have your lazy sheet inside the shrouds. It should be in front of everything. Also, If you can, you should probably move your fair-leads forward a bit for that head sail.
I'm guess you realized that when you went to tack.
Also, It's difficult to tell from a photo. but I'd make a guess that your standing rigging needs some tuning. That head stay appears to have quite a big of sag to it.
PhilCarlson likes this.
tempest is online now
post #4 of 38 Old 08-07-2018
mbetter's Avatar
I think hanking on a hank-on jib is quite good advice, frankly. His lazy sheet looks fine as does the jib car position.
mbetter is offline
post #5 of 38 Old 08-07-2018
mbetter's Avatar
The forestay looks fine, the jib just isn't attached to it.
oysterman23 likes this.
mbetter is offline
post #6 of 38 Old 08-07-2018
It's hard to tell definitively from photo but a couple of suggestions:
The jib does not seem to be hanked on OR the forestay is way too loose. I almost think I see a reefing drum (to which jib is attached?) but I don't see the foil that would go with it, so not sure what's going on there.
Angle of sheet might be ok - rule-of-thumb is that it should point to mid-point of sail luff (leading edge).
Main does look baggy - the wrinkles suggest the outhaul could use some tension. Also, is the topping lift slack allowing boom to drop? I also don't see a downhaul (maybe it's there...) so make sure there is tension at luff too.
A pic from the far stern showing how the sail sets would be helpful.
Good luck!
s/v Miracle
PSC Flicka 20
Totuma is offline
post #7 of 38 Old 08-07-2018
Yeah, Sorry, I didn't see that. I saw the drum, and missed the hanks.
post #8 of 38 Old 08-07-2018
overbored's Avatar
here is the original manual this might help the OP and others. did not read the whole manual so I don't know if the info is correct or not.
http://www.codysguide.com/spirit28/s...rit-manual.pdf
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
tschmidty (08-08-2018)
post #9 of 38 Old 08-07-2018
mbetter's Avatar
I'm now actually wondering if it's one of those furling sails with the integral wire luff. Regardless, those are garbage and the sail appears to have hanks so hank it on.
mbetter is offline
post #10 of 38 Old 08-07-2018
Is that one of those new-fangled loose luffed jibs?
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
Reefing ties remaining on the main? Good or bad practice? Guyfromthenorth General Discussion (sailing related) 10 08-12-2015 04:24 PM
Electrical - I did a bad bad thing (alternator / regulator) blowinstink Gear & Maintenance 21 05-05-2015 09:12 PM
Trouble and bad weather on one of the main Med races PCP General Discussion (sailing related) 11 11-01-2014 01:25 PM
Got it bad, sooooo bad uncleated Introduce Yourself 2 08-16-2013 09:24 PM
Free O Day - How bad is too bad ? ? ? nogin General Discussion (sailing related) 52 03-20-2011 10:40 AM
