Winch placement - SailNet Community
 4Likes
  • 1 Post By paulk
  • 1 Post By svHyLyte
  • 2 Post By Jeff_H
post #1 of 10 Old 10-29-2018 Thread Starter
davidpm's Avatar
Winch placement
https://providence.craigslist.org/bo...721565109.html
Can anyone tell me why there are winches near the mast on the cabin top?
Also, the placement of the other winches seems a little atypical.
davidpm is offline
post #2 of 10 Old 10-29-2018
Senior Moment Member
SloopJonB's Avatar
Re: Winch placement
Back then it was commonplace for halyard and topping lift winches and the like to be placed there. Prior to the advent of rope clutches when there was a winch for every line, they weren't usually led aft.
SloopJonB is online now
post #3 of 10 Old 10-29-2018
Re: Winch placement
What ever happened to real rigging where the lines came down to the little fence around the the mast step (pin rail) and belayed on the whatchma calits (belaying pins?) Now if you mention 'bowse'n tail' someone says geuswuntite.
Capt Len is online now
post #4 of 10 Old 10-29-2018
paulk's Avatar
Wink Re: Winch placement
JonB's avatar shows what can happen when the mast-crew doesn't get word when to let the halyard go.
SloopJonB likes this.
paulk is online now
post #5 of 10 Old 10-29-2018
Old as Dirt!
svHyLyte's Avatar
Re: Winch placement
Foredeck/Spinnaker Crew need immediate access to the winches for the Spinnaker Halyard and Pole Lift. Moreover, a deck mounted winch is easier to handle when conditions get snotty, particularly when one needs two hands for the winch. (And you're a "Sailing Instructor"?)
adki110 likes this.
svHyLyte is offline
post #6 of 10 Old 10-29-2018
overbored's Avatar
Re: Winch placement
seems like a bad place for the winches to me. would be very hard to access, no where to stand or kneel. standing on the deck it would be a long reach over the cabin top to crank the winch and the shrouds are in the way to stand there. I they are for the spinnaker then the boom would be just over the leeward winch and that would be dangerous. a quick gib set and one less crew member. I have sailed on many big boats with winch farms but never one with the winches that close to the mast, they are either on the mast or on the edge of the cockpit where you can get close enough to operate them, looks like a home brew location to me. on most C&C 37's I have seen there are Dorados on those humps
"GOLD RUSH" PRINDLE 16
overbored is online now
post #7 of 10 Old 10-29-2018
BarryL's Avatar
Re: Winch placement
Hey,
When I saw your post I immediately thought "old C&C with a winch farm." I have raced on a number of older C&C boats (34, 36, etc.) and they all came with non-self tailing winches right near the mast. One for the main halyard, another for headsail, and a few for spinnakers too.
Very typical, and not at all easy to use.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #8 of 10 Old 10-29-2018
Master Mariner
capta's Avatar
Re: Winch placement
I saw a Norseman today that had her winches around the mast base. It looked so ridiculous. Sitting on your butt on the cabin top with no way to brace yourself or hold on if using both hands on the winch and line, trying to haul up the main or a headsail? And then one must crane their head at an odd angle to watch what's happening aloft, completely taking one's attention away from the winch and line below you, not right in front of you as they would be on the mast! At least if the winches are on the mast one can pull the sail most of the way up by hand, only using the winch to top it up. And then somebody invented those safety bars around the mast base to support one's self on when working sails and the whole thing became even safer.
I can see it on a full on racer with a full crew, especially for handling chutes and the like, but it makes absolutely no sense to me on a shorthanded cruising boat.
Lastly, let's just place our winches on the boat where actual water will often flow over them, instead of on the mast or behind the dodger where they will get occasional spray only.
As for 'pin rails' and 'belaying (tying off) pins', they were used as cleats in the days before sailing vessels had winches and used blocks and tackles for handling sails. On a true gaff or square-rigged sailing vessel, the halyard passed around a hook-like fitting on the deck and then to the pin rails. The pin rails themselves were not strong enough to haul a sail up taunt.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #9 of 10 Old 10-30-2018
Administrator
Jeff_H's Avatar
Re: Winch placement
As others have said, you are looking at what was called a winch farm. This was standard race boat practice from the late 1960's through the early 1980's. The idea was that this was before the common use of two speed- self-tailing winches and line-locks. Halyards were wire with a rope tails and the wire was wrapped several wraps around the winch when the sail was fully hoisted. Winches were under sized by modern standards.
As a result In those daya, there was a dedicated winch and cleat for each halyard and each major control line. On a sail hoist there would be a trimmer and grinder for each halyard and sheet, and so work areas were purposefully spread out around the deck which resulted in the winch farm that provided space to have two people working together and not get into the way of other trimmers and grinders.
Today, a single pit person with adequately sized, self tailing, two speed winches and line-locks has replaced two crew members at the mast.
BarryL and SanderO like this.
Jeff_H is online now
post #10 of 10 Old 10-30-2018 Thread Starter
davidpm's Avatar
Re: Winch placement
Thank you all. It all makes sense now.
davidpm is offline
Winch handle in winch glassdad General Discussion (sailing related) 19 05-11-2011 05:10 PM
wierd winch placement jobi Gear & Maintenance 17 07-14-2010 01:46 PM
Spin pole downhaul block placement cmj Gear & Maintenance 0 08-05-2002 04:39 AM
centerboard line re-placement texas bob Gear & Maintenance 0 10-22-2001 10:28 AM
Electronics placement stewpee Gear & Maintenance 1 04-20-2001 04:00 AM
