Crazy first time out on my sailboat today - Page 3 - SailNet Community
 29Likes
post #21 of 68 Old 11-04-2018
Re: Crazy first time out on my sailboat today
Ok you donít get it.....as evidenced by making excuses for what you did. You did something very unsafe.
That diatribe is way over the top, and uncalled for, as you don't know enough details to condemn him like that.
Back OT, I am wondering what the two holes are that the water is draining from in the first pictures you posted of the boat sitting on the trailer.
TimMarks is offline
post #22 of 68 Old 11-04-2018
chef2sail's Avatar
You are entitled to your diatribe as I am mine. Your opinion is noted.
Proof is in the results. 4 individuals with life jackets on and 150 gallons in an untestedboat.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
ďSailing is just the bottom line, like adding up the score in bridge. My real interest is in the tremendous game of life.Ē- Dennis Conner
chef2sail is online now
post #23 of 68 Old 11-04-2018
......I am wondering what the two holes are that the water is draining from in the first pictures you posted of the boat sitting on the trailer.
As I understand the OP, these were the cockpit scuppers. Is that right?
This would mean that water completely filled the cabin, came up on the cockpit floor and only the cockpit drained out.
That seems odd, not to mention extreme.
Do these scuppers have hoses that lead from the cockpit to the hull? Some do, some are molded in. Looks like the outlet is below the water line, so it too is suspect to have actually caused the leak.
A 1" hole that is 2ft below the surface will flow at the rate of 28 gallons per minute. Obviously, the OP's leak was much smaller or shallower, as they would have never been out for the half hour they describe, with any easily noticeable hole.
Jeanneau 54DS
Minnewaska is offline
post #24 of 68 Old 11-04-2018
JimsCAL's Avatar
One additional item in the second pic in your post #12. That is a gate valve (and plastic!) and needs to be changed to a proper seacock.
S/V First Tracks
1985 Cal 33-2
JimsCAL is offline
post #25 of 68 Old 11-04-2018 Thread Starter
I believe you are correct. Those scuppers lead to holes just below the waterline. To access the back side they are behind a wood panel that blocks the fore side of the lazarettes. There is no reason to have below water through hull fittings on this boat.
There was no water at my feet in the cockpit. Obviously there is a break in those hoses. When the boat was on the trailer it wasn't forward and tilted aft having the water pour out. Once the boat was level those holes were much higher than the water level in the cabin.
I will be plugging those holes and the sink drain.
Thanks
Mike
1983 Starwind 19
Planning on getting this boat wet before the season is past me ... and keeping the inside dry !!!
MikePNJ is offline
post #26 of 68 Old 11-04-2018 Thread Starter
Thanks Jim, yeah that will be removed. No reason to drain a sink below the waterline. That's why we use Purell on board. No sink needed for quick bathroom usage.
Mike
1983 Starwind 19
MikePNJ is offline
post #27 of 68 Old 11-04-2018 Thread Starter
Ok you don’t get it.....as evidenced by making excuses for what you did. You did something very unsafe.
Thanks Tim, you were correct, Missing something so ridiculously obvious at the time!
Mike
1983 Starwind 19
MikePNJ is offline
post #28 of 68 Old 11-04-2018
I really do not understand why many have the need to go off on topics like this. He asked for help on where the water was coming in. He obviously knew he should have checked the boat out better before he got in it, and certainly before a full complement of people were out on the lake. Then the holier than thou group jumps in and tells the guy who is on his first sailboat how a true "captain" would never make this mistake. It is kind of like going to church for the spiritual aspect and getting a sermon on politics.
Recently saw a quote that has been attributed to many, but my favorite was Winnie the Pooh.
"Good judgement comes from experience. Experience?....that comes from poor judgement".
Give the guy as break. How many people here have not done some dumb ass stunt that has put ourselves or others at risk? Or do you lie to yourself about it?
1Nomad and MikePNJ like this.
tomandchris is offline
post #29 of 68 Old 11-04-2018
The CAPTAIN is the one who is responsible. Period
Your decisions MUST always be made with safety in mind first. You failed to do that and were pressured by another person to take guests on an unproven to you boat you had never previously tested. You should have said no.
So what is was a lake .
so what it was calm.
So what it was good weather
You took out an untested boat you donít know well with passengers and endangered everyone. Had someone gotten hurt or injured in this escapade who do you think would be held liable?
YOU WOULD
Thankfully nothing really happened. You get a second chance. If you donít correct this poor judgement decision starting by owning it , you will repeat. The water is not forgiving, not prejudiced and should be respected. If not your life....than others.
Sorry to be so blunt....b
Sorry to be blunt , but your a arrogant a**hole, they definitely banned the wrong person , smack would have suggested solutions not stand on top of his dockbox and preach a unneeded sermon.
Seeing winters coming plan on replacing all below waterline hoses , you don't have many so cost will be minimal, all new clamps, put proper seacock(s) on , and seeing you have a trailer sailor when your ready pick a dead day at the lake , leave the boat hooked to the cable on the trailer stay right at the ramp , grab a six pack , and watch for water ingress , if you drink the whole six pack and have no water inside , time to try some maneuvers with someone poking around down below to see if anything happens turning to port/then starboard , centerboard down then up ...
MikePNJ likes this.
dinosdad is online now
post #30 of 68 Old 11-04-2018
Mister don't run with the scissors here (you know the guy who usually gets stabbed when the person running with the scissors turns to ask why they shouldn't run with a pair of scissors in their hand).
When I got my current boat which had been sitting for years unattended I started by replacing the rigging but then got my phone and stuck my arm in every access point and snapped pictures of every place I could and could not see reviewing them on a computer monitor enlarged and brightened. Things that looked questionable in any fashion were removed and re-bedded at the least with some replaced. Mine is a picnic boat so it was even harder to inspect under the cockpit with very few inspection ports and no lazeretts that one could open. Having an in transom rudder that exited the hull below the water line I cleaned up the seal area on that, replaced the bedding and added a collar outside where it exited the hull to give it even more sealing area and to reinforce it. After I washed out the bilges I put the bilge plug in, filled the boat to the water line with fresh water and inspected for any drips or damp areas on the outside of the hull and found none. Water did not come out of the cockpit scupper thu-hull when there was only water in the bilge which is as it should be.
When launch day finally came I put it out and tied it to the dock for a few hours while I inspected for any leaks or seepage and finding none then I buddied up with a well seasoned sailor and we took the boat out for a trial and the only event was that 2 senior citizens went out sailing a 15 picnic boat in 15 mph winds coming back with smiles on their faces.
I believe you learned that you have to inspect and double check every hose and fitting on that hull and probably have some bedding and old hose to replace along with some corrections of questionable repairs done by previous owners and possibly a through hull to replace. Each spring when you get the boat ready for the water you will need to inspect those hoses and thu-hulls again. On first launch of the season allow time for the boat to sit at the dock for enough time to inspect for water coming in. Be mindful that plugging a thru-hull that's not bedded correctly is not going to stop it from leaking between it and the hull. Also make regular checks of the centerboard trunk along with the centerboard cable seal, pivot and lock pin areas for leaking or fracturing. Also check the leading edge of the centerboard trunk for any signs of damage as many times the centerboard can slam that area and crack the glass.
Continue inspecting and be mindful of how things are supposed to work and don't arbitrarily start plugging everything as you may find yourself doing a lot of bailing when water splashes in the boat. Its not a lot of fun when a self bailing cockpit doesn't drain and every bit of water that splashes over the bow or rail just builds up around your feet. Note that a water scoop made out of an old bleach bottle (milk bottles are too flimsy) can be a wonderful thing to have on board just in case.
Have fun with it and I believe most here will be looking forward to when you report you've found and slayed the dragon.
chef2sail and MikePNJ like this.
SeaStar58 is offline
First night sail, first time out of sight of land Minnesail General Discussion (sailing related) 13 08-05-2013 06:52 PM
First time out today. utchuckd General Discussion (sailing related) 12 04-07-2013 04:04 PM
Thinking about buying my first boat. Am I crazy? Pointy_End Learning to Sail 30 01-09-2012 03:04 PM
Crazy is as crazy does Crazy Introduce Yourself 37 01-03-2012 11:01 PM
First time Owner... First time Poster... mtmd Introduce Yourself 0 06-25-2008 05:17 PM
