electric uma - SailNet Community
 10Likes
post #1 of 13 Old 11-15-2018 Thread Starter
davidpm's Avatar
electric uma
My favorite cute sailing couple had a little discussion about sailing with electric propulsion.
If you don't want to bother watching the whole thing I like his main takeaway.
An electric propulsion motor doesn't replace a diesel motor it replaces a sculling oar.
These kids have been doing it for a few years now so despite making some mistakes they have really made it work.
They have sails rigged both light and heavy to sail in just about anything.
They have an anchor and chain for a boat twice their size.
They are willing to wait for the right weather and tide.
They seem to be a reincarnation of the Pardie's and this guy Ditch the Engine part 2-meet the "Oarclub" founder
It is not for most of us that need to keep a schedule but it is cool that they are making it happen.
The other two couples are not in the water yet so time will tell if they are committed to the electric thing as UMA.
CVAT and elliowb like this.
davidpm is online now
post #2 of 13 Old 11-15-2018
Learning the HARD way...
eherlihy's Avatar
Re: electric uma
I gave up on Sailing Uma when they did their bathroom remodel. In that episode, they confessed that they don't have a holding tank, and jerry-rigged a 4" PVC pipe in order to meet the letter of the law - despite the fact that they plan to anchor in NDZs along the US coast. Until the remodel, they had been getting by with a 5-gallon bucket and sawdust with a toilet seat.
davidpm and MastUndSchotbruch like this.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #3 of 13 Old 11-15-2018
eherlihy's Avatar
Re: electric uma
Oh yeah, their confession was accompanied by their justification that discharging overboard while anchored is "sailors dirty secret." implying that everyone does this. I do not, nor do people that I sail with.
post #4 of 13 Old 11-15-2018
Old enough to know better
Re: electric uma
Well I would say most cruisers do, it is just a matter of reality. Especially where they have been cruising as there are no pump out locations, so dumping is the only option. Some areas in the Bahamas it might actually be hard to even get 3 miles offshore as once your 3 miles from one island your going to be getting within 3 miles of another. So dumping within the 3 mile limit is the only practical solution, unless you go composting head. That said one should still be careful of where you dump, such as not in a reef or other area that has still water like a canal or harbor. Though I do think they should have included a simple gravity style holding tank a bit bigger so when they are in more sensitive areas and or in harbors and inland waterways they could use the tank. They are not hard nor expensive to build into a remodel of the head.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #5 of 13 Old 11-15-2018
Re: electric uma
I think there new solution with the lithium ion that will give them about 4 hours of range should be OK. They tried using normal lead acids and I don't think they ever got more than 10 min of range, that is sculling oar range. Not to mention that they did not seem to get more than a couple of months of use with lead acid. The lithium ion batteries cost about what a diesel rebuild would cost so it is to try to eliminate there reliance on fossil fuels, that I applaud them for but it is not for most sailors.
1976 C&C 33
post #6 of 13 Old 11-15-2018 Thread Starter
davidpm's Avatar
Re: electric uma
Originally Posted by miatapaul View Post
I think their new solution with the lithium ion that will give them about 4 hours of range should be OK. They tried using normal lead acids and I don't think they ever got more than 10 min of range, that is sculling oar range. Not to mention that they did not seem to get more than a couple of months of use with lead acid. The lithium-ion batteries cost about what a diesel rebuild would cost so it is to try to eliminate there reliance on fossil fuels, that I applaud them for but it is not for most sailors.
Yes, they seem to be hard on batteries. The lithium batteries they packed in very tight with no ventilation so we will see how long they last.
They do seem to manage to get from point a to b somehow though.
post #7 of 13 Old 11-15-2018
Re: electric uma
They are now into themselves being popular....famous social media whatever.
Seeking and getting freebies.
No logic behind that elec conversion for cruising travel.
The attitude, i guess....not into 'them'.
mbianka likes this.
RegisteredUser is online now
post #8 of 13 Old 11-16-2018
Re: electric uma
Not sure why they had such issues with lead acid batteries. My first set of AGM batteries for my Electric Propulsion system lasted eight years. Actually only one of the batteries started to go south. I replaced all four in 2017 instead of just the failing battery to keep them the same age range. The three good batteries probably could have gone ten plus years. My two 12 volt house bank Gels are still going strong at ten years though.
I had a little faux pas with the new EP batteries. Two were visibly damaged in shipment. So I had them replaced under warranty. I should have rejected all four as I found one of the visibly undamaged batteries was failing this season. I still got through the season with it by going into hybrid mode with the Honda 2000 when the bad battery voltage started to head below 11.8 volts. I'll be replacing it next spring.
I'm still not going for lithium mostly since the price has not really come down as much I thought it would. Also the complexity of needing a BMS (battery management system) adds to more electronics to fail. But, that's just me. The AGM's did a pretty good job at a good price point.
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is online now
post #9 of 13 Old 11-17-2018 Thread Starter
davidpm's Avatar
Re: electric uma
Originally Posted by mbianka View Post
Not sure why they had such issues with lead acid batteries. .
I don't remember the details but they did something known to kill batteries. It was a learning experience for them.
mbianka likes this.
post #10 of 13 Old 11-18-2018
Re: electric uma
Yea, I get that, but I have watched them since they started, I think literally saw the first episode when it came out. At the time they started I had a deal fall through on a Person 36, and so I kind of identify with their projects. So I can see past the current flow of freebies and paid endorsements as they have been out there working hard to make good quality content. Kind of feels like watching my kids (as I have some older and some younger) growing. I hope they get back out there soon and get back to what they do best. (IE not DIY stuff)
1976 C&C 33
Anyone using an Electric Trolling Motor (vs. Electric Outboard) gregcorey Gear & Maintenance 21 06-04-2018 12:53 PM
Head - electric conversion or new electric head snw Gear & Maintenance 5 04-29-2007 08:07 AM
SP trying to help Sonia win in Rae Bareli: Uma (The Times of India) NewsReader News Feeds 0 04-19-2006 05:15 PM
SP trying to help Sonia win in Rae Bareli: Uma (Outlook India) NewsReader News Feeds 0 04-19-2006 03:15 PM
Electric windlass - options Guylain Gear & Maintenance 8 05-01-2001 04:48 PM
