Cleaning control lines - Page 2 - SailNet Community
 7Likes
post #11 of 22 Old 11-19-2018 Thread Starter
Re: Cleaning control lines
Originally Posted by RegisteredUser View Post
I wouldve thought double polyester rather than nylon
Brain spasm, on my part. They are indeed double braid poly.
Jeanneau 54DS
Minnewaska is offline
post #12 of 22 Old 11-19-2018 Thread Starter
I canít say for sure the bleach was even necessary. I didnít try a control. I have to wonder if the weakening is impacted by the amount of bleach used. I used only a tablespoon for a load.
In any event, it the only time theyíve been cleaned in 10 years. The dirt and grime were undoubtedly weakening the line too. Iíve never seen a line like this part in the middle, unless it was chafed. I bet the over engineering will likely accommodate the loss. Iím going to redo the eye splices, as they are minorly chafed inside.
I washed one line at a time. If I had two in there, I think Iíd prefer the mesh bags for each. Pillow cases canít allow as much flow and these lines had some real dirt I would presume would be captured inside a pillow case.
Jeanneau 54DS
post #13 of 22 Old 11-19-2018
Minnesail's Avatar
I washed my four halyards this fall. I put them in mesh laundry bag, used a half dosage of our regular detergent, and washed them on hot. They came out great. I should have daisy chained them, since they did tangle a bit, but it wasn't too bad.
My halyards are Control DPX from Samson.
Catalina 22
on a starboard tack
Minnesail is offline
post #14 of 22 Old 11-19-2018
pdqaltair's Avatar
I'm not sayin' I have not washed lines. I have.
* Not often. 5 years.
* No bleach. Long soak, then wash in bucket or pillow case.
* Treat with water repellent like Nikwax. Or don't even bother washing. It REALLY helps.
Heck, probably 80% of the line I have used in the last 25 years has come from the recycle bin. People throw line away because it is dirty, and some of the racers bin it because it was from last year.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #15 of 22 Old 11-25-2018
The most female moderator
Donna_F's Avatar
Dock
Originally Posted by eherlihy View Post
Somewhere in my past I remember reading that you can clean lines in a household dishwasher. Knots and fraying are not an issue, and dishwashing detergent, supposedly, will not harm the line. I have not tried this, however.
When we had our smaller boat I washed the lines in the clothes washing machine. I decided to skip the mesh bag/pillow case step. BIG MISTAKE. I invented one new giant knot (aka a knotted mess).
The lines were wonderfully clean, however. Just a touch of clothes detergent. No bleach. Dishwasher detergent is mostly bleach.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #16 of 22 Old 11-25-2018 Thread Starter
One should tie the line into one of these first. No knots after washing for me at all. Some of the links elongated, but that was it. Came right apart.
https://www.animatedknots.com/chainsinnet/
I'm trying to put the new eye splices in this morning, but my fids are on board and my improvised pen cases, etc, are not working well. Looks like I'm ordering a home set of fids. Can't believe how many things I have on the boat and at home. Ugh.
MastUndSchotbruch likes this.
Jeanneau 54DS
post #17 of 22 Old 11-29-2018
I tried washing my jib sheets in a mesh bag in my top-loading washer, and they came out just as dirty as they went in!
I can see how a front-loader might do a much better job.
dixiedawg is offline
post #18 of 22 Old 11-29-2018
midwesterner's Avatar
Washing machine? How about a 5-gallon paint bucket, or they have those 15 gallon Rubbermaid storage boxes. I would recommend carpet cleaning shampoo, as it is designed to not leave residue and to leave synthetic fibers pliable. Also has a grease cutter and an antifungal agent.
Then you can hoist it over a tree limb or haul it up the halyard on the mast, to let it drip dry.
midwesterner is offline
post #19 of 22 Old 11-29-2018
pdqaltair's Avatar
I tested washing lines secured different ways; whether bucket or machine, the chain sinnet (daisy chain) seemed to best protect the line from damage and allowed it to move around just enough to scrub. It also dries faster.
post #20 of 22 Old 11-29-2018
SanderO's Avatar
R&W Ropes has a sale... I bought new reefing lines - 4 of them... from ends... over 200' x 3/8" staset... $80. Good deal...
Old lines will be given to cut up for fender lines... dinghy pennants and so forth.
pay attention... someone's life depends on it
SanderO is online now
Control lines for Lewmar traveller size 2 benesailor Gear & Maintenance 10 04-24-2014 05:51 PM
Moving control lines to the cockpit? Garffin Seamanship & Navigation 9 11-29-2009 04:58 PM
Control lines set-up for singlehanding OhioTom Seamanship & Navigation 9 08-28-2009 10:48 PM
Leading Control Lines Aft chtaylor Gear & Maintenance 57 08-23-2008 12:25 AM
Leading Sail Control Lines Aft Sue & Larry Gear and Maintenance Articles 0 08-11-2003 08:00 PM
