Thru Hulls 1989 Catalina 30 - Page 2 - SailNet Community
 5Likes
post #11 of 29 Old 11-26-2018
Dirt Free
boatpoker's Avatar
Re: Thru Hulls 1989 Catalina 30
Originally Posted by fallard View Post
Y the argument over the names of corrosion resistant Cu alloys is still semantics.
OK, I'll try one last time. If you think it's just semantics, read this article from Professional Boatbuilder Magazine ... "Beware the Brass"
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #12 of 29 Old 11-26-2018
fallard's Avatar
Originally Posted by Don0190 View Post
My first boat would have ruined that record. I have one being held in by caulking.
But the point is valid and I don't understand why people replace valves "just because"
Per the Catalina Direct 30 site (https://www.catalinadirect.com/index...ball-valve.cfm) immediate replacement of the bronze nipples and “garden variety gate valves” used in early Catalinas is in the “must do” category. Their suggested replacements are plastic.
IMHO, metal underwater is to be avoided where possible and practical. I don’t care whether it is brass or bronze or stainless because you are dealing with an electrolyte and the potential for stray currents in addition to the potential for dissimilar metals, leading to galvanic corrosion. Sometimes you can’t avoid metals, like for prop shafts, and sometimes the metal solution is superior, like for most props, but you do have a choice when it comes to standard thru-hulls and seacocks.
fallard is online now
post #13 of 29 Old 11-26-2018
SanderO's Avatar
How do these bronze of whatever type bronze they are... fail? Do they corrode away and lose so much strength that they break apart? If so wouldn't there be tell tale signs before it went critical?
pay attention... someone's life depends on it
SanderO is online now
post #14 of 29 Old 11-26-2018
Dirt Free
boatpoker's Avatar
Manganese bronze typically contains 35 - 38% zinc, it dezincifies with anything more than their natural voltage potential and can waste away just like your zinc anodes.
post #15 of 29 Old 11-26-2018
SanderO's Avatar
So if it appears completely intact with no sign of corrosion it would be fine.... Is this correct?
post #16 of 29 Old 11-26-2018
Dirt Free
boatpoker's Avatar
Not necessarily, the corrosion can be in the threads which you can't see.
Take a look at this article from Paul Stevens
Mainesail also has an article on this issue that you may wish to search out.
post #17 of 29 Old 11-26-2018
SanderO's Avatar
Thanks for the link. I think I will change all mine next haul out... which will be a short haul next spring. Pro active maintenance.
post #18 of 29 Old 11-26-2018
If in doubt about the fittings connecting to the ocean, just woop with a mallet every couple of years. That's more proactive maintenance than many boat owners give their maybe brass maybe bronze or is it plastic???thruhulls.
Minnesail likes this.
Capt Len is online now
post #19 of 29 Old 11-26-2018
Minnesail's Avatar
Originally Posted by Jac123 View Post
I am considering replacing the thru-hulls and seacocks on this new to me Catalina.
Catalina Direct sells nylon replacements for a reasonable price.
Is this the best way to go?
Any info on products and/or installation is appreciated.
My first project on my Catalina 22 was to replace the 40-year-old factory glassed in gate-valve Notes on a thru-hull replacement
I upsized and went with the Groco bronze fittings. This was relatively expensive and complete overkill. If I had to do it over again I'd still go a size bigger, but I'd do Marelon instead of bronze.
The process seemed a bit daunting, especially as my first ever boat project, but I followed Mainsail's instructions and everything went great.
RegisteredUser likes this.
Catalina 22
on a starboard tack
Minnesail is offline
post #20 of 29 Old 11-26-2018
Out here in the primitive hinterland, metal recycle yards have bins of good enough ball valves of SS316 (pulp mills , boilers and breweries.) $1 /lb. Hard to worry about overkill .
Looking at 1989 Catalina Capri 22 wander701 Boat Review and Purchase Forum 6 05-06-2016 10:32 AM
Catalina 30 Thru-hulls geetcher Catalina 3 03-17-2016 05:29 PM
1989 27' Catalina fresh water levels jayr4203 C27 2 03-16-2015 01:50 PM
1992 Catalina 36 or 1989 Pearson 36 Midnightflyer Boat Review and Purchase Forum 3 10-11-2012 02:01 PM
2000 Catalina 250 Keel vs. 1989 Pearson 27' Harpmary General Discussion (sailing related) 13 02-02-2010 10:56 AM
