First you tube sailing channel(s) ? - Page 11 - SailNet Community
 84Likes
post #101 of 108 Old 01-09-2019
Moderator
Arcb's Avatar
Re: First you tube sailing channel(s) ?
Here is a sample of a location review. This one is Chaffeys Lock historic lock station on the Rideau Canal.
I don't have any rules, but I do have some guidelines. One is to include some boating footage in the area (sailing if I can) to give folks an impression of the nature of the boating in the area, this one is nearly %50 local sailing before arriving at the lock station. Definitely some shots of available docking as well as the locks as I think that is of primary interest to boaters. I got lucky on this one and there happened to be a free outdoor folk festival to close the video off with. Even at 12 minutes, there is still a ton of useful information missing (most of which can be found in the cruising guide).
2400 views, which, I think is above average for my location reviews.
MarkofSeaLife and mbianka like this.
Arcb is offline
post #102 of 108 Old 01-09-2019
Moderator
MarkofSeaLife's Avatar
Dock
Originally Posted by willyd View Post
Just curious - at what stage do you plan the cut-aways (I assume these are the ancillary shots of dolphins jumping, halyards slapping, etc.)? Are they planned at all?
Great question. Its things like cutaways that make a good video and easier to edit. My 1 shot videos generally dont have any cutaways whatsoever. This makes them easy to make but theres scripted 'virtual' cutaways still there.
It takes quite a bit of learning, and then remembering to get them.
For others who dont know what a cutaway is (example): If you are talking to camera and point to sea and say "see those dolphins jumping? Thats because theyre looking for fish..." At the moment of "jumping" you need to insert a closeup shot of dolphins jumping.
Or: "Look at this screw Im holding" You see some small object in your hand, but then you cutaway to a close up shot of it.
Or: In an interview you take shots of the interviewer reacting to the interviewee (or their hands etc) so in edit you can edit out irrelevant stuff by cutting away from the interviewee to a shot of something else and back again.
Obviously thats difficult footage to get so you might use old footage.
Generally you need to use footage shot on the day so the light is correct and the colour temp, quality and technical aspects are the same.
Yes they are planned insomuch as you know when doing any interview you need to get them. Do them at the end of the interview, or when setting up.
Every setup you shoot you must remember to get the cutaways at the end before moving the setup. Otherwise the camera has moved position and you'll forget.
So the beginner wants to write them in the script AND do them anyway.
So my scripts will always use 4 shots: Establishing Est, Wideshot WS, Closeup CU, and extreme closeup (and cutaway) ECU. Theres lots more shots but these are the scripted ones I use.. the others are made up on the job.
So a script might look like:
Est: Boat; Presenter on foredeck
WS: Presenter
CU: Presenters face
ECU: Object in hand or being referred to.
These are also edit points so any time you need to cut something from the CU you just go to the WS or the Est, or a ECU cutaway.
As I said before its very difficult to remember to do cutaways because you're so excited about finishing your main shot and you forget.
Every good director will tell you you never can have too many cutaways. Editors will tell you that you should be able to tell the story with just cutaways.
In my 1 shot videos there are no cutaways! It saves me a lot of time.. but there are 'virtual' cutaways pre-scripted in each video. i.e. I know what we need to have a close up of so I will hold it in shot longer. It certainly doesnt work as well as proper editing, but Im not bothered to do all that... id prefer to drink rum.
Last thing to remember: each time you do shoot something you could use in a later video remember to mark it, note it, file it. Those jumping dolphins you must be able to find again!
mbianka and Mikael like this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
willyd (01-09-2019)
post #103 of 108 Old 01-09-2019
Moderator
Dock
Originally Posted by Arcb View Post
What was your audio arrangement? There was very little wind noise.
Its just the camera mic.
Rehearsal
I speak loudly to get over most noise.
luck.
mbianka and Arcb like this.
Sea Life
post #104 of 108 Old 01-09-2019
FYI a gal I worked with in television had recently just finished her first novel called THE CUTAWAY. A murder mystery based on just such a editing technique used in the TV biz.
MarkofSeaLife likes this.
Mike
Currently: Hunkering down for a bit.
mbianka is online now
post #105 of 108 Old 01-12-2019
Gemini 105Mc
Davy J's Avatar
So with this thread in mind, I broke out a camera on New Years day and recorded some video of the day. Even though we have four iPhones, a GoPro, a Sony point and shoot and a DJI Phantom 3, this video was shot with one iPhone 7. Unfortunately, the audio on the phone leaves something to be desired. And I will be looking into a fix for that.
I edited it using Pinnacle Studio HD. I am a little rusty using the software so it probably could be done in shorter time, but it took about four hours to edit the video, add transitions, add text, add some background music and edit the original audio. All that resulted in 7 minutes of video, not sure I would want to make a full time job of it.........
I also learned a bit about optimum video resolution and data rates for YouTube that I didn't know before.
Mikael likes this.
Davy J is offline
post #106 of 108 Old 01-13-2019
Can we start another thread (workshop) where you teach us (and we give feedback to each other) how to make great sailing videos?
I'm almost certain I want to give it a shot when we receive our new boat next summer and it would be really good to learn more about it before that.
There's a lot of theory to it, of course, but I also think it would be nice to have a "study group" where we could show videos to each other and get feedback on what's working and what's not.
Just an idea.
Mikael is offline
post #107 of 108 Old 01-13-2019
Moderator
Dock
Sure. Give me a day and I'll start a thread in Videos/Cruising Videos and we can all contribute.
Mark
Sea Life
post #108 of 108 Old 01-13-2019
Moderator
Dock
OK Made a thread
https://www.sailnet.com/forums/cruis...post2051576466
Mark
Sea Life
Cool ongoing you tube series Shortnsalty General Discussion (sailing related) 6 05-01-2014 04:38 PM
Where can you get clear heat shrink tube? jarcher Gear & Maintenance 3 05-12-2010 04:38 PM
Add a "You Tube" icon T37Chef Announcements and Suggestions Box 18 03-04-2010 03:35 PM
Dual channel vs single channel AIS teshannon Gear & Maintenance 17 03-22-2008 03:42 PM
Cool You Tube Videos NewsReader Mass Bay Sailors 0 06-13-2007 12:15 AM
