Securing companionway? - SailNet Community
 10Likes
post #1 of 18 Old 12-22-2018 Thread Starter
I am trying to find the best way to secure my companionway while underway. I sail a 1990 Catalina 28. I want to be able to access down below from on deck or below, but not get swamped if we take a wave. I mostly stick to the SF Bay and Delta, but I plan to venture down the coast to Pillar Point or Monterey this summer. Anyone know a good method? Thank you.
Valleysail is offline
post #2 of 18 Old 12-22-2018
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Re: Securing companionway?
Customarily companionway boards in place and hatch latched but not locked works. Alot of folks rig heavy lucite for a top board so any swing out screens can be seen. b ut depending on how you rig screens may not be a problem
Sent from my SAMSUNG-SM-G930A using Tapatalk
oysterman23 is online now
The Following User Says Thank You to oysterman23 For This Useful Post:
Valleysail (12-22-2018)
post #3 of 18 Old 12-22-2018
Barquito
Barquito's Avatar
If you want a robust off-shore setup you need to be able to secure the hatchboards without the need for the hatch lid. You could add some sort of spring loaded barrel bolt that has a handle on both sides of the board. Here is a picture of a nice one that I stole off another site.
Valiant 32
Barquito is online now
The Following User Says Thank You to Barquito For This Useful Post:
post #4 of 18 Old 12-22-2018
I mounted two barrel slide bolts on my bottom hatch board. ( I have 3 boards) That locks in from the inside, but you can reach it from the cockpit when the two top boards are out.
Just for the picture ---> https://www.zoro.com/zoro-select-bar...CABEgKb0vD_BwE
I suppose I could do the same for the 2nd board and 3rd board.
However, I just drilled a small hole in the top board on a downward angle toward the cockpit so that minimal water gets in ( actually none ever has) and mounted small cleats just below the bottom board. That allows me to tie a knot on one end of the line and lock the boards down from inside or out.
tempest is online now
The Following User Says Thank You to tempest For This Useful Post:
post #5 of 18 Old 12-23-2018
GeorgeB's Avatar
Valleysail, is your hull number 100? (If so, I know that boat!). Pillar Point (Half Moon Bay) is a great one day sail from the Bay. Santa Cruz is a nice second day and Monterrey a third. You can do Pillar - Monterrey in a single shot, but in your 28 it will be an overnight. Don't sweat the hatch boards. Catalina makes them pretty tight fitting so they don't easily come out. If you are still concerned about the lower board, I drilled a hole through the inside fiberglass and a little "divot" in the the board and use one of those spring locking pins. This is really a requirement for the ISAF Offshore Racing Special Regulations and not required for coastal sailing. (To be compliant, you also need a way of securing the sliding hatch).
Barquito, that is a pretty cool way of securing a hatch board! How thick is the board? mine are only 1/2 thick. Will it work on mine?
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is online now
The Following User Says Thank You to GeorgeB For This Useful Post:
Valleysail (12-23-2018)
post #6 of 18 Old 12-23-2018 Thread Starter
George B, I am hull 31. I am just trying to make the boat as safe as I can. I have to make sure the Admiral has a good time and feels as comfortable as possible. She is considering driving home while I bring the boat back up the coast.
post #7 of 18 Old 12-23-2018
I use a bungee from steps to boards. Have 3 boards total
1 board is looped bungee.
2 boards is not looped.
Quick, secure and no fumbling or construction
RegisteredUser is online now
The Following User Says Thank You to RegisteredUser For This Useful Post:
post #8 of 18 Old 12-23-2018
In practice, I think you will find your fear of being swamped unnecessary, don't project your fears on the admiral or she'll never be able to relax and enjoy herself.
"Just call me TB"
capttb is online now
The Following User Says Thank You to capttb For This Useful Post:
post #9 of 18 Old 12-23-2018
Master Mariner
capta's Avatar
I absolutely hate hatch boards, so I made a door out of Starboard for our companionway in an afternoon. It just slides into the groove for the hatch boards and is about as strong as hatch boards. A barrel bolt at the inside top keeps it closed when needed at sea and one at the inside bottom adds security when we aren't aboard.
companionway door inside.jpg   companionway door outside.jpg   companionway door.JPG
contrarian and Valleysail like this.
ďBelieve me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.Ē ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
The Following User Says Thank You to capta For This Useful Post:
post #10 of 18 Old 12-23-2018
Barquito
Barquito's Avatar
I just copied a picture from another boat.
Valiant 32
securing companionway from inside rmeador Gear & Maintenance 31 10-07-2010 07:46 PM
Securing Companionway Drop Boards ccriders Gear & Maintenance 3 06-01-2009 08:18 PM
Securing Shroud Turn-Buckles SEMIJim Gear & Maintenance 23 08-25-2007 10:34 PM
Securing the Rode tagster Seamanship & Navigation 1 08-02-2007 03:20 PM
Securing centerboard when trucking a vessel roger_mexico General Discussion (sailing related) 2 10-20-2005 06:35 AM
