What makes a good sailboat for large following seas? - SailNet Community
 54Likes
post #1 of 39 Old 12-29-2018 Thread Starter
My largest concern is coming into a New Jersey inlet with breaking following seas, pitch polling, and being swept sideways into the rock jetty. With power boats I can remain at a high enough speed to match the swell. With a cruising sailboat I canít do that.
Iím thinking a boat with a large skeg hung rudder would be best for handling such a situation.
What do you think ? Is there other items I should consider as I look at a purchasing a coastal cruiser ?
Sent from my iPhone using Tapatalk
skeggs is offline
post #2 of 39 Old 12-29-2018
SchockT's Avatar
Re: What makes a good sailboat for large following seas?
How big are these following seas you speak of, and how often do you expect to encounter them?
I dont think having a skeg hung rudder will make much difference if the seas are big enough to toss you sideways into the rocks! Getting into that kind of trouble is more likely going to be caused by bad helmsmanship not rudder design!
I think you are worrying too much about one particular scenario that you are not likely to encounter very often in coastal cruising. Get the boat that suits your every day cruising needs, then learn how that boat handles following seas.
Sent from my SM-G960W using Tapatalk
MarkofSeaLife and capta like this.
2011 Jeanneau 39i Azura
SchockT is online now
The Following User Says Thank You to SchockT For This Useful Post:
skeggs (12-30-2018)
post #3 of 39 Old 12-29-2018
and gain the experience to judge when the best course of action is to Just Wait for acceptable conditions.
Sailing, not power boating.
MarkofSeaLife likes this.
john61ct is online now
The Following User Says Thank You to john61ct For This Useful Post:
skeggs (12-30-2018)
post #4 of 39 Old 12-29-2018
paulk's Avatar
Maybe something like this would be suitable:
They seem to be quick enough to stay out ahead of most of the breakers. No skegs visible.
Check Yachtworld for "IMOCA 60"
cb32863 likes this.
paulk is offline
The Following User Says Thank You to paulk For This Useful Post:
skeggs (12-30-2018)
post #5 of 39 Old 12-29-2018
outbound's Avatar
Surfing tons and tons of boat is a blast but requires a very responsive helm. From my limited experience the balance spade / fin combo is most immediately responsive. Depending on design it maybe one or two rudders. Some hold direct linkage or a tiller helps. Some believe worm gear or hydraulic steering should be avoided. Some feel being able to sense the sea throyour hand helps.
s/v Hippocampus
Outbound 46
outbound is online now
The Following User Says Thank You to outbound For This Useful Post:
skeggs (12-30-2018)
post #6 of 39 Old 12-29-2018
Moderator
MarkofSeaLife's Avatar
Dock
What we call a Bar... not not with beer
The rule is to stay outside until the weather moderates... even if its days... I have done this particular entrance, the Southport Seaway in Australia... ummm its a tad scary.
Mark
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
skeggs (12-30-2018)
post #7 of 39 Old 12-29-2018
SanderO's Avatar
After the storm in the Marion Bermuda when we were thru the Stream we encountered immense following mountains of water. The rudder was almost useless and to not roll or broach we had to drive as straight as possible down the wave if memory serves me correctly. I can't even imagine trying to get through a narrow channel with immense following seas.
pay attention... someone's life depends on it
SanderO is online now
The Following User Says Thank You to SanderO For This Useful Post:
skeggs (12-30-2018)
post #8 of 39 Old 12-29-2018
Mark
thats a famous/popular one.
He caught it right.
There are situations where you dont get a mulligan.
Keep the grey cells tunned up
RegisteredUser is online now
The Following User Says Thank You to RegisteredUser For This Useful Post:
skeggs (12-30-2018)
post #9 of 39 Old 12-30-2018 Thread Starter
Thank you for your replies.
Im considering a cruising sailboat which is 30 to 34 ft in length. The idea of a skeg rudder is that the increase resistance will help keep the stern from slipping. I believe Bill Crealock had this in mind when designing the Pacific Seacraft 34 and 37. Compare those boats to a spade rudder boat of the same era such as the Pearson 34 or 33. Given the shallow shoals of NJ a deep keel is not an option. Here is a photo which is not an uncommon situation. Its my many years of experience which is telling me to prepare for handling the bad before going out, and in this case, consider it when selecting the boat. Im also considering it with where Iím going to dock her and what inlet Im going to be using. While the admiral will compare interiors, Im trying to find the proper fit, marrying dock, bay, inlet, boat.
Sent from my iPad using Tapatalk
SanderO likes this.
skeggs is offline
post #10 of 39 Old 12-30-2018
Moderator
Dock
If you know the particular port as you appear to, then I would be sitting on that breakwater and watching what boats go in an out... or more importantly what boats don't use it at all, and which boats do well or poorly.
Then I would dockwalk the local marinas and do a survey, and chat to owners.
Local knowledge is 200% of the battle in some places.
Just an example I can think: Is this particular entrance straight? or does one have to surf and do a dog-leg at the same time?
BTW I think the skeg thing is a red herring. If 40 year old design principles were principals they would be used now. They are not. But thats only my opinion, half the forum thinks anything built before the 1880's is better than anything built today
PS Is your User name and your liking for skegs any correlation?
Mark
skeggs likes this.
Sea Life
skeggs (12-30-2018)
Fair winds and Following seas design. CoastLife General Discussion (sailing related) 0 05-23-2017 07:55 PM
Wellmet, fair winds and following seas. AnMjones Introduce Yourself 2 03-20-2010 08:55 AM
Fair Winds and Following Seas lsbrodsky Pacific Seacraft 10 03-25-2009 11:49 AM
A bit of following seas... CharlieCobra Seamanship & Navigation 30 01-11-2008 06:16 PM
