Electric circuit modifications - SailNet Community
 6Likes
post #1 of 20 Old 01-02-2019 Thread Starter
OK, next question regarding the new to me 1982 Catalina 30:
Current arrangement:
VHF on same circuit as cabin lights (not sure why. . . probably been that way for many years).
Knotmeter on its own circuit**
Depth sounder on its own circuit**
**Binnacle compass light on same circuit as either knotmeter or depth sounder. . . I need to check next time at boat)
I've read various things about VHF--that it belongs on its own circuit, that it should be direct to battery, etc. Similarly, I read somewhere that depth sounder should be on its own circuit. I don't know why this is the case, perhaps the VHF can cause (or is susceptible to) interference.
At any rate, here's what I'd like to do. I don't think I'd be overloading any circuit.
Combine knotmeter and depthsounder (and compass light) into ONE circuit.
Move VHF to the newly freed-up circuit (now on its own).
Bonus: the compass light wires are tantalizing and right at the helm. I'd love to tap into these with waterproof crimp/adhesive heat shrink (nice Ancor brand stuff) and add 12V outlet to power iPad at helm.
Comments?
jnorten is offline
post #2 of 20 Old 01-02-2019
Re: Electric circuit modifications
Originally Posted by jnorten View Post
.....Comments?
Standard comment. 12v electrical fires are the number one cause of fires aboard boats, by far.
Be sure you are certain about codes and proper installations. Not sure there is enough data in your post on amp draws, distances, wire sizes and breaker sizes to answer your question. I'm not a pro, I have to look all this stuff up every time.
Jeanneau 54DS
Minnewaska is offline
post #3 of 20 Old 01-02-2019
Master Mariner
capta's Avatar
Absolutely the only thing, IMO, that one could possibly want wired directly to the batteries (with a fuse in the line) would be your electric bilge pump. Please notice that I said could possibly want because that is the case, and I prefer not to do this. However, we do not ever turn off our main 12 volt electrics when we leave the boat, as some do.
Your VHF is a fairly high draw item for a small boat and should be appropriately wired (appropriate wire size for the wire length) to its own circuit breaker.
chef2sail likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #4 of 20 Old 01-02-2019
Learn if the compass light wiring will safely carry enough juice for ipad.
RegisteredUser is online now
post #5 of 20 Old 01-02-2019
BarryL's Avatar
Hey,
You current set up seems strange to me. Why would you want to turn on the cabin lights just to turn on the VHF?
I *PREFER* to have similar items on a single breaker. For example. I have a switch labeled 'instruments' and it turns on my plotter, depth, wind, and knot / log. I have a separate breaker switch for 'VHF'.
My compass light is turned on when I turn on the 'running lights'. Why would you want the compass light on during the day?
My last point, I don't think the compass light wiring would be sufficient to power a cigarette lighter. Those can typically power 10 amp or higher devices. The compass light wires I have seen are tiny, and probably could not supply more than 1amp without overheating.
If you want to make modifications to your boat please do some more research and be careful to do things the right way. I would suggest that if you want 12V power at the helm that you run new wires from the panel to the pedestal. It won't be that difficult and you will learn a lot more about your boat.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #6 of 20 Old 01-02-2019
Originally Posted by BarryL View Post
My last point, I don't think the compass light wiring would be sufficient to power a cigarette lighter. Those can typically power 10 amp or higher devices. The compass light wires I have seen are tiny, and probably could not supply more than 1 amp without overheating.
Easy solution: don't install a cigarette lighter. Install a USB port. That only draws about 1A (at 12V to produce 2.1A at 5 V). Or if it is a dual USB outlet: 2A maximum. Even 16 gauge wire is sufficient for this.
Like the Blue Sea Systems dual USB outlet. That is what I installed in one of my NavPods.
But like Barry said, you are still better off running it as a separate (fuse protected) wire.
BarryL and RegisteredUser like this.
TimMarks is online now
post #7 of 20 Old 01-02-2019
contrarian's Avatar
Vhf should be on an isolated circuit.
You could most likely combine the instruments and compass binnacle light on another circuit.
12 volt receptacles are nice but you need to make sure the feed wire is properly sized for amperage as well as voltage drop.
contrarian is offline
post #8 of 20 Old 01-03-2019
Master Mariner
capta's Avatar
Originally Posted by TimMarks View Post
Like the Blue Sea Systems dual USB outlet. That is what I installed in one of my NavPods..
How the devil do you keep the USB port from corroding away? I never take my computer topside and the USB ports corrode like mad. I'm down to 1 from 4 on this computer.
capta is online now
post #9 of 20 Old 01-03-2019
SanderO's Avatar
You got a mess to sort out. I would begin with a new circuit panel. Decide on how many circuits you. The switches on the panel could be breakers or have separate breakers. Order a panel with several spares as you may get new equipment that you want to isolate.
This is a place to start:
https://panelwizard.bluesea.com/
an example:
https://www.bluesea.com/products/837...s_White_Toggle
This is high quality reliable gear and their systems are adaptable/flexible. I personally would not mix AC and DC though they offer these panels too. My AC panel have only a few items and is separate.
You may be able to re use your old panel, but it's probably a good idea to upgrade that.
pay attention... someone's life depends on it
SanderO is online now
post #10 of 20 Old 01-03-2019
Lots of good advice. Likely, but not guaranteed, most of these changes would work. I'd be most concerned about adding to the binnacle circuit, as this is probably a fairly low amperage lamp in the compass, and maybe fed by a pretty thin wire that could be overloaded with a cig. lighter plug where 10 amp devices might be powered.
It sounds like some hay wiring was done to this boat. Very common when a boat's been thru many owners over many years. I'd run through everything, figure out what the amp ratings of the circuit breakers are, look at the gauge of the wires to each device, and look at the amp ratings of the loads, and make sure everything is within spec. Electrical fires can ruin your whole day.
Good luck.
capecodda is online now
Mast Modifications Sue & Larry Gear and Maintenance Articles 0 03-15-2002 07:00 PM
Modern Modifications Dan Dickison Racing Articles 0 07-11-2001 08:00 PM
