Plastic Prop??? - Page 2 - SailNet Community
 1Likes
post #11 of 13 Old 03-11-2019
Re: Plastic Prop???
I'd heard of one from Oz, probably the Kiwi, years ago. At that time it was not CF but was an engineered resin. The idea being that the amount of curve in the blades SHOULD NOT be the same at all speeds, and by using a slightly flexible blade (plastic) you can actually build a prop that changes curve to work better as the prop speed increases.
At the time they were supposed to be a novel idea and a good thing. I think PS tested them out, coupla decades ago.
hellosailor is offline
post #12 of 13 Old 03-11-2019
Learning the HARD way...
eherlihy's Avatar
Re: Plastic Prop???
Originally Posted by scubadoo View Post
Should be able to pull a water skier!!
Like this?
scubadoo likes this.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #13 of 13 Old 03-12-2019
Siamese's Avatar
Re: Plastic Prop???
Originally Posted by eherlihy View Post
Interesting...
1996 Catalina 28 MKII:
Displacement: 8,300 lb / 3,765 kg
Engine: Universal M-25XP
HP: 23 @3200RPM
1985 Catalina 34
Displacement: 11,950 lb / 5,420 kg
HP: 21 @3000RPM
1984 O'day 35
Displacement: 11,500 lb / 5,216 kg
HP: 21 @3000RPM
1982 Ericsson 35-3
Displacement: 13,000 lb / 5,897 kg
HP: 21 @3000RPM
Bit of a thread hijack here, but yeah, it's a big engine for a 28. A slightly tubby, 28 maybe. I can tell you that here on the Great Lakes, it's nice having that extra punch. We'll often go up the Lake Michigan coast for a few days, and on the way home we're going straight into 5-6 foot, steep Lake Michigan waves. In those situations, it does not seem like we're overpowered.
One might assume that Catalina had these engines on the shelf for their other models, and it was simpler to stuff it into the 28.
Siamese is offline
Small outboard plastic prop? asdf38 Gear & Maintenance 4 06-24-2013 06:53 PM
Plastic prop issue Fstbttms Gear & Maintenance 12 05-08-2009 09:51 PM
plastic thruster prop jms2550 Gear & Maintenance 3 11-09-2007 11:24 AM
Plastic paint for tired looking plastic parts Goodnewsboy Gear & Maintenance 3 01-01-2007 06:15 AM
plastic prop grey99 Gear & Maintenance 7 12-19-2002 01:43 PM
