What packs in anchor locker better? Nylon or Chain? - Page 3 - SailNet Community
 4Likes
post #21 of 27 Old 04-27-2019
Re: What packs in anchor locker better? Nylon or Chain?
Originally Posted by Minnewaska View Post
This is why I chose to say "I’m a fan of all chain, unless it’s not a viable option". The question is in the eye of the beholder to determine what a successful outcome may be. Some search for boats with 10 second PHRF rating differences and consider that an important characteristic. Others never know the difference. Clearly, the boat will continue to sail with this marginal added weight, it's only a matter of whether the skipper and boat can tell the difference in characteristic.
There are pros and cons to different rode setups. Some seem to feel a need to defend their choice. I simply say I prefer all chain, where viable. I can't say if it's viable in the OP's boat. Only they can.
The OP question, however, was which will fit more length. That's been definitively answered.
Agreed, but I don't understand some of the negativity around giving the OP one more factor to consider while making their choice. The point is to help them make an informed decision by sharing our knowledge and experience is it not?
chicory83 is offline
post #22 of 27 Old 04-27-2019
Nothing wrong with sharing opinions and additional thoughts, so I'm not sure what negativity you're referring to.
No doubt, when it comes to many sailing topics, there are many differing points of view.
Jeanneau 54DS
Minnewaska is offline
post #23 of 27 Old 04-27-2019
pdqaltair's Avatar
To the OP:
It helps if you fill in your profile so that we know what type of boat you have.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #24 of 27 Old 04-27-2019
pdqaltair's Avatar
Originally Posted by capta View Post
I can't imagine any proper vessel designer would not take into account the anchor and chain weight when drawing a boat's lines. That would be toral incompetence IMO....
Really.
But then there are all of the owner add-ons, the dinghy on-deck, the reacher....
Of course, the designer should have expected that too.
(No strong personal preference between chain and rope--it depends on the boat and the use and I have had both... but the OP did not share boat information.)
post #25 of 27 Old 04-27-2019 Thread Starter
I think I'm going to wind up with something like 150' feet of chain and 100' of nylon. Or maybe 125' of each. That's if we can gain more space, by moving or eliminating the partition.
If things are simply too tight, I may have go with, say 100/100.
I know we can gain some more space. The question is whether the nylon, going in first, will spread enough to allow more rode period.
mainemandean is offline
post #26 of 27 Old 04-27-2019
Master Mariner
capta's Avatar
Originally Posted by pdqaltair View Post
Really.
Really? You might want to reread post 18?
You've been sailing multihulls for a while now and you seriously don't think the designers didn't put anchor lockers in them in specific places? Most cruising multihulls (and monohulls for that matter) have very specific anchor lockers, reinforced for the extra weight and sectioned off for a couple of sets of gear, from my experience. Perhaps you figured all that just ended up there by chance?
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #27 of 27 Old 04-27-2019
pdqaltair's Avatar
I was agreeing with you and joking with you. I'm sorry You somehow perceived the reverse meaning of what I intended. Perhaps it was unclear writing on my part.
On any given boat the designer should have allowed for anchors, rode, dinghies and gear appropriate to the intended use. On a light weight boat the allowance will be less, on a heavier boat it will be more. My last boat, a cruising boat, used all chain, had a windlass and very large chain locker, and a dinghy on davits, and carried all of that weight well. My current boat is much lighter and uses rope rode and a kayak for a dinghy. Both are correct.
My point was that we occasionally see boats that are tragically overloaded. Folks add stuff that would be at home on a larger boat but that crowds a small boat. You need to be thoughtful when adding stuff, and if you really need a larger boat, sell and move up. The larger boat will carry the weight better.
We also see boats that were built over weight and drag transoms before they are loaded. I can think of several clear examples. The PDQ 36 comes to mind; they need transom extensions or a serious diet in most cases. But they need more help than a little less chain.
But generally I would think if a boat came with a windlass, the designer was figuring on all-chain.
capta likes this.
Chain to chain connectors on anchor chain kwaltersmi Gear & Maintenance 12 10-16-2013 09:24 AM
Anchor chain ... locker micheck Cal 4 06-15-2011 06:31 PM
Pirate Queen Packs Up Ship Before Sailing to Broadway (Playbill) NewsReader News Feeds 0 11-26-2006 01:15 AM
Community packs a punch (The Star) NewsReader News Feeds 0 10-10-2006 07:15 PM
Dehydrated Food Packs Low Salt bgitt Provisioning 2 03-21-2005 07:13 PM
