Quickly connecting nylon to chain in emergency. - SailNet Community
 2Likes
post #1 of 21 Old 04-26-2019 Thread Starter
I may be storing a nylon rode in a bag on deck, but my anchor (the secondary) will be on a bracket on the pulpit, and its chain will go down a hawse pipe into a small locker space. The chain's bitter end will not be attached to the boat.
I am looking for the best way, in an emergency, to connect the nylon to the chain. The nylon would have a thimble on it.
What is the safest "missing link" to use? A SS carabiner hook? If not, what?
Is there any way to do this without needing something that would require seizing with wire? I am imagining being in a hurry.
Suggestions will be greatly appreciated.
mainemandean is online now
post #2 of 21 Old 04-26-2019
Señor Member
ottos's Avatar
Re: Quickly connecting nylon to chain in emergency.
You're kind of defining an anchor shackle. Seizing isn't required (in the short term) if you secure the pin with a good amount of force using a key, pliers, or wrench.
Edit: I suppose you could use a mooring hook which would be faster, but less reliable...
ottos is offline
post #3 of 21 Old 04-26-2019 Thread Starter
Thanks, ottos. Obviously, I thought about a regular shackle; and I already have a few spares on the boat. But I was hoping for something just a bit quicker to deploy, if possible, without any tools.
But you may be right, and I'll just do that. I could always have the needed tools in a special place for quick access. And I could leave some zip-ties in the bag or with the tools, for quick better-than-nothing seizing.
post #4 of 21 Old 04-26-2019
It’s good practice to have the bitter end attached to the boat in a way you can release quickly. My bitter end is three strand rope chain spliced to chain. The bitter end is tied to an eye, rope is so long that I can cut the rope outside the chain locker. Also long enough to tie a knot to connected to extra rope.
knuterikt is offline
post #5 of 21 Old 04-26-2019
celenoglu's Avatar
The most reliable method
celenoglu is online now
post #6 of 21 Old 04-26-2019 Thread Starter
My anchor will be hanging on a pulpit mount; it cannot self-launch; the chain cannot get away from me. I will just pull the chain out of the locker and connect it to the rope, at an eye/thimble on the forward end. The rope will be bitter end of the rope will be permanently secured to the boat while in the bag, and in addition will be cleated off on deck when in use.
In reality, I have not used my spare anchor in fifteen years, and don't expect to. But I have to have something in case I'd have to abandon my primary somewhere, or something even more dramatic happened.
I appreciate all the help.
post #7 of 21 Old 04-26-2019
Master Mariner
capta's Avatar
You don't mention the boat you are sailing, but it is unlikely you will find anything more suitable or secure as a regular old galvanized shackle. Stainless would be much more likely to undo itself and is susceptible to anaerobic corrosion.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #8 of 21 Old 04-26-2019 Thread Starter
It's a Cape Dory 31. It weighs about six tons.
It looks like I'll probably be going the shackle route. Thanks.
post #9 of 21 Old 04-26-2019
chef2sail's Avatar
Please don't leave the bitter end non connected.
Please don't plan in an emergency to go up and connect anything on the foredeck
Please don't start handing connecting chain on a pitching deck.
Anchors are part of safety. They can get you out of a jam or give you time we to stabilize,use a situation should you have a failure or an engine , mast or anything major on the boat. Or even in case of an injury.
Anchors and their accompanying tackle needs to be able to deployed quickly. The anchor needs to bite without necessarily having to back down on it. ( I suggest a new gen Rocna or Manson).
Don't just think of your anchor being put down in lazy quiet anchoring creeks. Consider it may save you bacon in an emergency so make it easy to deploy.
SanderO and Scotty C-M like this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #10 of 21 Old 04-27-2019
I can't imagine anything being faster or simpler than attaching a shackle. However, I'm not following what kind of emergency you're trying to accommodate. I would not want to have to do this routinely, but you said emergency. Your primary rode should never be able to run out the end. That would certainly cause an emergency.
If you provided a bit more about what your primary set up was, perhaps there would be some more constructive feedback to be had.
Jeanneau 54DS
Minnewaska is offline
What packs in anchor locker better? Nylon or Chain? mainemandean General Discussion (sailing related) 26 04-27-2019 08:32 PM
Chain to chain connectors on anchor chain kwaltersmi Gear & Maintenance 12 10-16-2013 09:24 AM
To quickly spot your boat Debz Gear & Maintenance 10 07-06-2007 11:14 AM
Morales quickly discovers his flaw (Los Angeles Daily News) NewsReader News Feeds 0 11-18-2006 05:15 AM
The Creep / Spammer came back as quickly as I deleted him, Now I mus NewsReader Mass Bay Sailors 0 05-26-2006 07:15 PM
