Crazy first time on my sailboat .... part 2 - Page 2 - SailNet Community
 7Likes
post #11 of 12 Old 05-02-2019
Re: Crazy first time on my sailboat .... part 2
These are cockpit scuppers, which seem to drain at or just below the waterline. I suspect this 19 ft boat doesn't have any other hull penetrations? Si o no?
Jeanneau 54DS
Minnewaska is offline
post #12 of 12 Old 05-02-2019 Thread Starter
The scuppers drain aft to 2 holes below the transom, at/below the water line.
I picked up some Shields under the waterline rated hose.
There is 1 other through hull where my sink drains. I will need to replace the plastic valve to that. I originally wanted to plug it because the sink is basically a place to hold keys and a wallet max. After the previous discussion and seeing some other links, I'm probably going to connect a bilge pump to that sink line through hull. I want to see if any water penetrates in from there.
Another concern is the pendant from the drop keel.
Few areas to look at, I'm not going to sail it, just drop it in and sit inside and look for water, feel the hoses and make sure they aren't wet or weeping.
Mike
1983 Starwind 19
Planning on getting this boat wet before the season is past me ... and keeping the inside dry !!!
MikePNJ is offline
Crazy first time out on my sailboat today MikePNJ General Discussion (sailing related) 67 10-23-2019 08:04 PM
Thinking about buying my first boat. Am I crazy? Pointy_End Learning to Sail 30 01-09-2012 02:04 PM
Crazy is as crazy does Crazy Introduce Yourself 37 01-03-2012 10:01 PM
First time Owner... First time Poster... mtmd Introduce Yourself 0 06-25-2008 04:17 PM
Extra green time for smooth sailing over new bridge: Extra green light time sought Extra green light time sought over (Asbury Park Press) NewsReader News Feeds 0 04-23-2006 05:15 AM
