Oven doesn't get to tempurature - Page 4 - SailNet Community
 15Likes
post #31 of 47 Old 05-09-2019
SchockT's Avatar
Re: Oven doesn't get to tempurature
Originally Posted by MarkofSeaLife View Post
Because it's electrical.
If you are at sea... I do long passages... And the electrics go bung suddenly you can't have quality food, hot beverages. Many boats can't dip for freshwater from their tanks not do they have manual fresh water pumps. Some don't have manual toilets.
On a catastrophic electrical problem suddenly you're in deep trouble.
If the law says you must, you must.,... But on my boat I take the risk as I see it. I'd rather food and water than a gas solinoid
I suppose you have a point, however I would argue that bypassing a solenoid is not difficult to do for anyone with even rudimentary tools and technical ability. If one was really worried about it, you can buy a permanent magnet designed to open solenoids, and keep it in your tool kit for just such an eventuality. (Heck, they are handy for magnetizing screwdrivers too!)
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #32 of 47 Old 05-09-2019
colemj's Avatar
Originally Posted by Davenier View Post
You only have two boats, Oh you poor man.
No, no. If you have one boat, you are a poor man. Two boats makes one an insane man.
And very, very poor.
You sound like someone who really needs a very nice 42' catamaran fully equipped for cruising with new rigging, new sails, electronics, the whole shebang.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #33 of 47 Old 05-10-2019
Owner 1973 C-41 Sloop
riggy001's Avatar
Send a message via AIM to riggy001 Send a message via Yahoo to riggy001
BWAHHH! No swizzle stick! (rhymes with something that is syn for "turd")! LOL! ROFL LMAO! THAT is because the US Govt mandated so much crap that it is NOT POSSIBLE to conform to ALL the regulations -- I even forgot the topic! I just ignore the government. Let them find me.
Read the gov advisos, see if it makes sense, (and most times it does (like "do not exceed 28 PSI with 8mm LPG hose with a hand made fitting, or 32 PSI with the same hose and a machine fitting").
Oh, and the ABYC Standard for having a solenoid switch in the galley is merely for keeping tards safe from themselves.
To be safe, if the gas is not turned off at the bottle, and there is no solenoid but the stove has a leak--even a tiny one--the LP goes into the bilge and is just as flammable as if it were on the stovetop. So, I would opt to have a solenoid for that reason alone. Red switch on = stove/oven enabled! I can deal with that! I just do not think GOVERNMENT has the RIGHT to DICTATE that I DO THAT! I just think, as I laid out the pros and cons, what happens if you do and what could happen if you don't, that it should be up to the individual to decide what to do.
When I install my gas system, I will have a solenoid.
Meantime, I have a solenoidless Cassette-Feu gas burner! And a microwave!
"So if I make instant coffee in a microwave oven, will I go back in time?" --Steven Wright.
riggy001 is offline
post #34 of 47 Old 05-10-2019
Originally Posted by riggy001 View Post
...the LP goes into the bilge and is just as flammable as if it were on the stovetop.
Actually, while I do not suggest anyone get cavalier with leaking propane, it requires a fairly specific gas/air mixture to be flammable. Ever try to start a BBQ with the gas running and it won't light? The stove top is designed for this mixture. Gas in the bilge may or may not be at this mixture and that's essentially impossible to know. Therefore, keep it out of the bilge. Just picking nits that it isn't necessarily just as flammable.
As I think I mentioned above, I think it's more important to know the solenoid can successfully shut the gas off. You'll know it's open, if you can get the stove lit. I want to see a lit stove go out each time, when I flip the solenoid breaker. Then I have less of a concern over closing the tank valve.
Our breaker for the solenoid is above the nav station on the other side of the salon. I changed the breaker to be Red, so it's quickly identifiable, in the event of a fire. I also think it's stupid to have it right in the galley, where flames may drive you out, before getting to the switch. When I shut down the gas, I leave the burner on, walk across to flip the breaker and look back to see the burner extinguish. Then I return and shut off the burner control knob.
Jeanneau 54DS
Minnewaska is offline
post #35 of 47 Old 05-11-2019
Cassidy's Avatar
It would take a stout heart to test for gas in the bilge with an open flame, though.
We use that exact process. The solenoid is a great way to avoid going out the back on a filthy night to shut the gas off. I wouldnít be without one to the extent that I have a spare in the parts locker.
Our cooker is a thirty year old Force 10 four burner with oven and grill. None of the peizo lighters work anymore and all the knob labels have long since been polished off but she still works great and bakes a decent loaf. If an oven canít develop enough heat to bake bread, it must be faulty - surely no manufacturer would spec an oven that canít bake bread. And IMHO, itís not the solenoid, if the top burners work OK then the solenoid is OK.
Cassidy is offline
post #36 of 47 Old 05-12-2019
" it requires a fairly specific gas/air mixture to be flammable. "
Funny thing about air:fuel mixtures. Or the way you can extinguish a lit match by throwing it into a bowl of gasoline. ("Kids, don't try that at home.")
At a high school homecoming bonfire, someone who was responsible for it apparently spread five-ish gallons of something on the wood pile around noon. And late in the afternoon, someone else did the same thing, again, for some reason. Not knowing it had already been done.
Around 7pm the fireball was about six stories tall, threw many things including an old chair a good fifty yards and hit someone when it came down. They couldn't have made a better fuel:air bomb if they'd been trying to.
Funny stuff, explosive gases. And when you consider, one gallon of petrol and much less diesel, properly vaporized and exploded many times, can move a 4000 car twenty miles...Just like the ocean, you've got to give it some respect. Or fear, either one may keep you alive.
Those piezo igniters? Wonderful concept. Maybe there's a barbeque engineer among us who can explain why they inevitably fail within a year. (Living next to an open flame probably has something to do with it?(G)
hellosailor is offline
post #37 of 47 Old 05-12-2019
Moderator
MarkofSeaLife's Avatar
Dock
5 gallons!?
Twice!!??
When I was in the army I used a flame thrower once. I think it held about 2 gallons of gasoline.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #38 of 47 Old 05-12-2019
Back then, the details never got out. It was bad enough that two faculty had somehow turned a rather large bonfire into a good bomb, we could only guess they had each borrowed "gas" cans from the grounds keeping crew. Which spent a long breeze-less Indian Summer afternoon vaporizing over the wood.
I doubt they could have done as well IF they knew what they were doing.
MarkofSeaLife likes this.
post #39 of 47 Old 05-12-2019
Cassidy's Avatar
I digress but FYI, in my experience the best fuel to safely start a bonfire is mineral turpentine - low evaporation rate so lights slowly but once lit, doesnít go out.
Cassidy is offline
post #40 of 47 Old 05-12-2019
Flame throwers....ive always wanted one.
Natural chain....comes after chainsaw
RegisteredUser is online now
It doesn't get any better than this : WM Sale NewsReader Mass Bay Sailors 0 02-16-2007 11:15 PM
Re: Fwd: It doesn't get any better than this NewsReader Mass Bay Sailors 0 02-16-2007 08:15 AM
