Oven doesn't get to tempurature - Page 5 - SailNet Community
 15Likes
post #41 of 47 Old 05-13-2019
Minnesail's Avatar
Re: Oven doesn't get to tempurature
Originally Posted by Cassidy View Post
I digress but FYI, in my experience the best fuel to safely start a bonfire is mineral turpentine - low evaporation rate so lights slowly but once lit, doesn’t go out.
When I was in scouting we called diesel fuel "Boy Scout water" because it was the safe, responsible alternative to gasoline or coleman fuel
Catalina 22
on a starboard tack
Minnesail is offline
post #42 of 47 Old 05-13-2019
Yep.
Diesel better if wood is wet too...longer burn...and dont need to toss lit match and run...
RegisteredUser is online now
post #43 of 47 Old 05-20-2019 Thread Starter
So I checked everything I knew to check, which wasn't much before the help of you wonderful folks, and I cleaned the oven burner as best I could. The oven heated up much more quickly, and actually got to 400, which was much hotter that it had gotten since we've owned the boat. So maybe simply cleaning the burner helped.
To be frank, I knew next to nothing about solenoids before I started this thread. And during then and now I did a bit more research and figured out that the previous owner completely disconnected the gas line from the solenoid control valve. The left-behind solenoid is cube-shaped of perhaps 1.25 inches on each side, and was simply left hanging from it's two electrical wires in the gas locker. There is a 1/4"-ish hole thru the center of it, and no place to theoretically connect it to the regular and supply hose.
I'm thinking I need one of these.
TRIDENT MARINE
12V Low-Pressure Brass 1/4" Solenoid Valve, part # 1300-7708.2-KT; or maybe the 3/8" unit.
bshock is online now
post #44 of 47 Old 05-20-2019
Cassidy's Avatar
The valve is good but you probably want to use pipe tails rather than threaded fittings. Something like these that will fit into the pipes and get crimped using proper gas line crimps.
F1D26C94-AC93-4DEF-9E88-1E777FB3D22E.jpeg   DE61D9A5-840A-48EE-914B-0D287F3EBDD2.jpeg
bshock likes this.
Cassidy is offline
post #45 of 47 Old 05-20-2019
colemj's Avatar
Most propane lines come with flare fittings like shown in his picture.
Mark
bshock and Uncle Bob the 1st like this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #46 of 47 Old 05-20-2019
When you have yellow fingers reaching out from one side of your burner..ring of fire..looking for marshmallows..its time to poke and free it.
Dont wait until the CDC would think your stovetop is an experiment...as mine is...
bshock and Minnesail like this.
post #47 of 47 Old 05-21-2019 Thread Starter
Thanks guys!
It doesn't get any better than this : WM Sale NewsReader Mass Bay Sailors 0 02-17-2007 12:15 AM
Re: Fwd: It doesn't get any better than this NewsReader Mass Bay Sailors 0 02-16-2007 09:15 AM
