Maxwell windlass question - SailNet Community
post #1 of 3 Old 05-09-2019 Thread Starter
I recently had a Maxwell RC8-8 (vertical axis) windlass installed on my boat. It seems like a generally good quality item.
In the very center of the windlass is a female winch handle socket, and the windlass comes with a winch handle. The winch handle is used in the socket to disengage the clutch, so one can freewheel the rode down; then one uses the handle to re-engage the clutch, for normal electric operation.
I like the design, BUT ...
At the bottom of the socket is the head of an allen bolt, which is used to hold the windlass together; the head of that bolt naturally domes up, so as to make room for the allen socket.
The problem is that this bolt head makes it impossible to insert the winch handle any further than about 1/4". It is hard to apply significant force (torque) without the handle popping out of the socket.
Does anyone else have this issue? It seems like a very odd design flaw, and one that could have easily been done differently. I can press down with the heel of the other hand, and get by or simple engage/disengage. But for any real control, to moderate the speed of a freewheeling descending rode, the setup is not good; it's too wobbly, not solid.
Thoughts? Comments?
mainemandean is offline
post #2 of 3 Old 05-09-2019
colemj's Avatar
Re: Maxwell windlass question
You might want to contact Maxwell - they are pretty responsive. Your windlass might not be right.
We have a HC10 - the horizontal version of yours, and a larger chainwheel. However, it has the exact same socket clutch and emergency retrieval system as yours.
Ours does not have the issue you describe. But ours also may be slightly different in design, even though it has the same functionality.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #3 of 3 Old 05-09-2019 Thread Starter
Thanks, Mark. I'll call them.
The handle is hollowed out, as if to fit over the bolt head. But after a point, it is hollowed out less; it is "stepped," I guess you'd say. It's that smaller-diameter part which is preventing it from going down over the head.
Maxwell H 650 Windlass tomperanteau Gear & Maintenance 2 05-26-2015 03:45 PM
Lewmar Lofrans Maxwell -Oh My -What Windlass to Buy CheckedOutRob Gear & Maintenance 15 12-22-2013 10:32 PM
Maxwell Windlass Neicy Gear & Maintenance 3 10-28-2009 02:43 PM
Maxwell windlass 1200 wookie General Discussion (sailing related) 0 08-20-2009 07:00 AM
Maxwell Windlass Reservoir richlerz C470 6 08-07-2008 05:42 PM
