What do you expect? - SailNet Community
 10Likes
post #1 of 23 Old 05-14-2019 Thread Starter
Master Mariner
capta's Avatar
What do you expect?
So often on here and other forums I hear the question; how long from X to X?
For those of us who had our boats a season or two, the answer is pretty simple.
So, on a good day, working sails only, what % of the wind speed would you expect to make, up to around 20/25 knots on a beam reach to a hard beat?
I guess it sounds an odd question, but I'm always trying to increase my performance in relation to wind speed.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #2 of 23 Old 05-14-2019
SanderO's Avatar
Re: What do you expect?
Not quite sure what the question is...
Beating seems slower as wind pipes up as waves slow you down more...
Light conditions and flat seas closer to the wind is a faster point of sail for Shiva... more apparent wind.
Beam and abaft of the beam wants more wind... but the waves seem to be less of a problem.
This is not the answer you want but I can't understand the % thing.
pay attention... someone's life depends on it
SanderO is online now
post #3 of 23 Old 05-14-2019 Thread Starter
Master Mariner
capta's Avatar
OK, I'll try again. Working sails only.
Obviously more wind, less sail to reach an optimum speed. Less wind means more sail to keep that optimum speed. Only works in a beam wind to hard on it. In that "slot" would you expect your boat speed to be around 40, 50, or 60% (or other) of the apparent wind speed? We do our best between 8 knots of wind and 18. After 18 the wind gusts too much to maintain a good average and the seas begin to affect the boat too much.
capta is online now
post #4 of 23 Old 05-14-2019
colemj's Avatar
Need to define whether you are talking about apparent or true wind speeds and angles.
An AWA beam reach up to 20kts AWS and we expect ~70% of that wind speed, although we are needing to reef at the higher end.
A beat at 32-35* AWA up to 20kts AWS and we expect ~50% of that wind speed, but again, we are needing to reef at the higher end.
After 20kts apparent, we pretty much keep the same speeds and angles, but are reefed. At 25kts apparent, we are beginning the second reef, and speeds drop to ~50% beam AWA beam reach, and ~30% AWA beating - mostly because the waves are taking their toll.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #5 of 23 Old 05-14-2019
Moderator
Arcb's Avatar
Is this exercise for planning purposes? When I am voyage planning I assume an unknown wind speed and collect data based on average VMG for the boat in all past conditions. I would typically assume higher VMG for areas of open water vs rivers, creeks and protected waters. I will make adjustments for very favourable conditions vs is unfavourable conditions. On average I assume the following;
Beach Cat 5 knots vmg (seems low but that is a calculated average obver 1000 miles).
Sharpie; 3 3/4 knots. She cooks in light air.
Sailing kayak. 3.2 knots. This is a remarkably stable number. I can almost gaurantee it will take me within an hour either way to cover 32 miles in 10 hours.
Arcb is offline
The Following User Says Thank You to Arcb For This Useful Post:
MarkofSeaLife (05-15-2019)
post #6 of 23 Old 05-14-2019
Schedules are a fool's errand
SanderO likes this.
john61ct is online now
post #7 of 23 Old 05-14-2019
Moderator
Arcb's Avatar
Um. Its navigation. Time, distance, speed.
Arcb is offline
post #8 of 23 Old 05-14-2019
Old soul
MikeOReilly's Avatar
I may not fully understand the question, so forgive me if I’ve got this wrong...
(I know you know all this…)
First off, I assume we’re talking apparent wind. Secondly, sea state matters big time. No seas, opposing seas, angled seas or following seas will affect progress.
That said, my boat will usually achieve hull speed on a reach to close-reach, as well as DDW, with 20-25 knots wind. For us this means a bit over 7 knots (theoretical hull speed is around 7.4 knots). I expect to see this anytime wind is around 15+ knots, again depending on sea state.
Close haul and broad reach is where we perform poorer. Here best speed might be around 6 to 6.5 knots.
For planning purposes I usually use a 5 knot average.
SanderO and capta like this.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #9 of 23 Old 05-15-2019
SanderO's Avatar
Don't the boat's polar diagrams answer your question?
post #10 of 23 Old 05-15-2019
colemj's Avatar
Curious why your performance DDW is better than a broad reach? Is it because you are wing-wing DDW with better projected sail area?
Mark
Minnesail likes this.
- Current boat
- Previous boat
colemj is offline
What do you expect a watch stander to to. davidpm General Discussion (sailing related) 16 11-03-2013 10:11 AM
How long do you expect to keep your boat/how long will it last? killarney_sailor General Discussion (sailing related) 50 12-14-2011 08:05 PM
How much human damage can you expect in a crash davidpm Seamanship & Navigation 22 12-01-2011 10:22 AM
What exactly does the Capt expect when you are on nite watch? rockDAWG General Discussion (sailing related) 18 10-22-2007 12:53 PM
