Add a battery? - Page 2 - SailNet Community
post #11 of 12 Old 06-17-2019
chef2sail's Avatar
Re: Add a battery?
Originally Posted by Gregrosine View Post
We have two batteries on our 1999 352 Beneteau; a 70 amp group 24, and a 135 amp 4D. I also have a 12v/55 amp alternator and a 20 amp battery charger. I only have the analog battery monitor that is original to the boat. What alterations do I have to make to add an additional house battery?
An example, and we have similar sized boats.
4-6volts would fit in the same space and give you 440 ah. Larger lead plates usually mean more deep cycles.
I would get a battery monitor , easy to install not expensive .
Here’s one but there are others
https://www.victronenergy.com/battery-monitors/bmv-700
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #12 of 12 Old 06-18-2019
Re: Add a battery?
The House battery is the one not used to crank an engine.
Are your two current batteries connected in parallel together at all times now to form a single bank?
Or are they currently separate, one Starter one House?
Usually the device to accomplish that is a VSR / ACR.
What are your current sources of charge inputs when out on the water? What are your usage patterns, how many days / weeks away from shore power?
If away extensively, what sort of loads, can you create an energy budget? You'd really want a true deep cycling bank.
Do you have a strong need for sealed (AGM or GEL), or is the (better vallue) option FLA acceptable for you?
A plain volt meter is not what we call a Battery Monitor these days, the current Victron model is BMV-712, but there are dozens of such coulomb-counting types available.
Another type is SmartGauge and SG-200 from Balmar.
Check out the electrickery posts at https://marinehowto.com , plenty of other DC Electric 101 learning resources coming soon.
john61ct is online now
