Add a battery? - SailNet Community
post #1 of 12 Old 06-17-2019 Thread Starter
Gregrosine's Avatar
Add a battery?
We have two batteries on our 1999 352 Beneteau; a 70 amp group 24, and a 135 amp 4D. I also have a 12v/55 amp alternator and a 20 amp battery charger. I only have the analog battery monitor that is original to the boat. What alterations do I have to make to add an additional house battery?
Gregrosine is offline
post #2 of 12 Old 06-17-2019
colemj's Avatar
Re: Add a battery?
I don't think you need any alterations to add a battery, but if the batteries are older than a year or so and have been used regularly, I wouldn't stick a new one in parallel with them. I have assumed the G24 was a start and the 4D the house.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #3 of 12 Old 06-17-2019
Re: Add a battery?
How much useable house battery do you think you want
What is age of the 4d
RegisteredUser is online now
post #4 of 12 Old 06-17-2019 Thread Starter
Gregrosine's Avatar
Re: Add a battery?
Both batteries were new last season.
post #5 of 12 Old 06-17-2019
colemj's Avatar
Re: Add a battery?
In that case, I don't think there is any issue with adding another battery in parallel to increase your capacity. You don't need to make any alterations, although you may wish to upgrade your battery monitoring.
The G24 is a start battery, correct? And you plan on adding another 4D, correct?
Mark
- Current boat
- Previous boat
colemj is offline
post #6 of 12 Old 06-17-2019
BarryL's Avatar
Re: Add a battery?
Hey,
If you have space in the battery compartment all you need to do is buy another battery. Connect is in parallel (plus to plus and neg to neg) with the existing house battery, and you done.
Of course make sure it's securely mounted, fused, etc.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #7 of 12 Old 06-17-2019
Re: Add a battery?
Originally Posted by BarryL View Post
Hey,
Barry
Like he said but I would move the neg to the new battery and leave the pos to the original, or vice versa.
Cheers, Uncle Bob the 1st from Sydney Aust.
Uncle Bob the 1st is offline
post #8 of 12 Old 06-17-2019 Thread Starter
Gregrosine's Avatar
Re: Add a battery?
Why?
post #9 of 12 Old 06-17-2019
chef2sail's Avatar
Re: Add a battery?
You are creating one large bank.
You 4 D ah seem light at 135 . Most are more powerful. If that’s true you only have 63 usable. For you boat, that’s kind of small, but I don’t know how you use your boat, nor it’s daily electrical diet. Refrigeration can eat up that 63 amps quickly.
I have heard the rule of thumb is that the alternator should be able to put out 25-40% of the battery bank. That keeps it from working to long and insures a quicker recharge.
4D are heavy at 80-90 lbs. hard for one person to maneuver. Maybe in the future you’d consider replacing them with 6 volt golf car batteries. At 45 lbs.
These are all general statements. I’d suggest reading up on the electrical system in your boat , one of the more expensive systems. It’s good to match battery ,capacity, battery usage, battery recharging or you can waste money.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #10 of 12 Old 06-17-2019
Re: Add a battery?
Originally Posted by Gregrosine View Post
Why?
Hi, I believe that by wiring this way it ensures that both batteries are discharged/charged evenly, = longer life.
