Flat dingy - SailNet Community
 16Likes
post #1 of 17 Old 4 Weeks Ago Thread Starter
Flat dingy
So can I just fill my inflatable dingy with super expanding foam? I can't find the leak. It has to be in the seam somewhere and money is tight right now. I was thinking some expanding foam and problem solved. Anyone heard or seen this idiotic idea tried before?
Cork_Knee76 is online now
post #2 of 17 Old 4 Weeks Ago
Re: Flat dingy
Slime works well in tubed tires...
I would work harder to find rhe leak
RegisteredUser is online now
post #3 of 17 Old 4 Weeks Ago Thread Starter
I have spent two weeks looking for the leak. It's super slow but it's really annoying. Do they have a slime that I could pour into a hole? My idea is that I drill a hole put the foam in and then patch the hope I drilled. Sounds fool proof but if it wasn't for bad luck I would have no luck at all. LoL
post #4 of 17 Old 4 Weeks Ago
Learning the HARD way...
eherlihy's Avatar
Re: Flat dingy
Sounds interesting to me. I know of a guy that dumpster dived for a dinghy, and filled the holy tubes with empty plastic water bottles. That worked,
Expanding Polyisocyanurate foam could work, BUT it will absorb water if it gets wet... Then you'll have a bigger problem, and the dinghy will be trash.
MarkofSeaLife likes this.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #5 of 17 Old 4 Weeks Ago Thread Starter
Empty water bottles. Now that's what I call recycling
post #6 of 17 Old 4 Weeks Ago
cj!
Re: Flat dingy
You can get inflatable tube sealant that you put in the tubes and roll around to coat all the surfaces. Don't put spray foam in there. If any water leaks in, it will get in the foam and you will end up with a heavy rigid dinghy that is now even worse to dispose of.
cj! is offline
post #7 of 17 Old 4 Weeks Ago
Moderator
MarkofSeaLife's Avatar
Dock
Re: Flat dingy
Yes, it's been tried often.
It does not work.
Reasons: Bought at a hardware store foam costs more than re-tubing a dinghy.
The result is pathetic. It's heavy, lumpy, bumpy, looks crap and doesn't motor nor row we'll. The foam under your butt deteriorates quite quickly untill you have an ugly broked blob of foamy puss that's impossible to fit in a trash can if you could lift it.
Re-tube; fix prefessiinally, or re-new.
Mark
eherlihy, capta and PhilCarlson like this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #8 of 17 Old 4 Weeks Ago
Master Mariner
capta's Avatar
Re: Flat dingy
I have no doubt that a professional inflatable boat repair shop could fix your dink for a lot less than the foam you are considering would cost.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #9 of 17 Old 4 Weeks Ago Thread Starter
That's what I needed to hear. Thank you everyone. I will see about getting it fixed the correct way.
MarkofSeaLife, capta, CVAT and 1 others like this.
post #10 of 17 Old 4 Weeks Ago
chef2sail's Avatar
Re: Flat dingy
It does not work.
Mark
FOAM PUSS......now there is a profound head picture🤡🤡🤡👽
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
