How to move jib / genoa cars literally, not when but how! - SailNet Community
 5Likes
  • 1 Post By overbored
  • 1 Post By overthehorizon
  • 3 Post By RegisteredUser
post #1 of 10 Old 08-25-2019 Thread Starter
Hello everyone,
I'm trying to figure out how to move my jib cars. They are most likely very old. They have a Harken block attached.
I'm trying to figure out how to get them to move on the track. I've turned the knob with no luck, just spins. Are you supposed to pull up on the knob? Press down on the pin and pull up at the same time? They won't budge and I definitely don't want to break them. I just wanted to know how to move them. They are currently set all the way aft.
I'm including a photo, it's an old picture I took last year but should be able to see what the jib car and track look like.
Thanks,
Mike
Mike
1983 Starwind 19
Planning on getting this boat wet before the season is past me ... and keeping the inside dry !!!
MikePNJ is offline
post #2 of 10 Old 08-25-2019
Re: How to move jib / genoa cars literally, not when but how!
Pull the pin up, slide to desired pinhole and release. Did you try that? If stuck, try spraying the pin with WD40 or a penetrating lubricant.
Jeanneau 54DS
Minnewaska is offline
post #3 of 10 Old 08-25-2019 Thread Starter
Thanks Minnewaska, l give it a try either later today or tomorrow. I tried pulling up on the black knob with no luck.
It figures, most sailing implements require the use of a tool to move something. Probably needle nose pliers to grip that pin.
Mike
Mike
1983 Starwind 19
MikePNJ is offline
post #4 of 10 Old 08-25-2019
Mike
It should be possible to lift the pin by hand. PO have not used/maintained it.
knuterikt is offline
post #5 of 10 Old 08-25-2019
overbored's Avatar
Looks like the old Ronstan internal c track. they used the small track size on the Hobie 16's. the pin should just pull up with the knob . yours looks like the 27mm size. most likely the pin is bent and jammed.
MarkofSeaLife likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #6 of 10 Old 08-25-2019
chef2sail's Avatar
Try PB Blaster then let it sit for a day. We put zipper pulls on stuff like that to insure a perpendicular pull.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #7 of 10 Old 08-25-2019
From lack of use, those pins get corroded in place. After doing as Minnewasaka says, and use a penetrating lubricant, it could very well take some tools to pry the pin up to get the car moving. Once the car can move, slide it off the track so you can wire brush it, clean it, and work the pin to loosen it properly. Should be easy to pull up when not under load.
RegisteredUser likes this.
overthehorizon is offline
post #8 of 10 Old 08-25-2019
Regularly stubbing your toe on them will help in keeping the free...
RegisteredUser is online now
post #9 of 10 Old 08-25-2019
krisscross's Avatar
Sometimes you have to pull the pin up and give the car a solid whack with a piece of wood to get it moving. Or take the whole rail out, clean, and rebed.
Plato
krisscross is offline
post #10 of 10 Old 08-26-2019
Minnesail's Avatar
We call this "percussive maintenance" or a "technical tap" and it sounds like just the thing in this case.
Catalina 22
on a starboard tack
Minnesail is online now
