SailNet Community (https://www.sailnet.com/forums/)
-   General Discussion (sailing related) (https://www.sailnet.com/forums/general-discussion-sailing-related/)
-   -   Throttle Wrench (https://www.sailnet.com/forums/general-discussion-sailing-related/331564-throttle-wrench.html)
trevorharris 10-08-2019 11:07 AM
Throttle Wrench
2 Attachment(s)
Hey all,
The shifter on my throttle was feeling fairly loose, so I disassembled it yesterday and found the problem. There is a rather strange looking nut that was loose and needed to be tightened. I've tightened it a fair bit by hand, but I feel like there must be some sort of custom wrench that fits the pattern. I've attached a photo illustrating this. The nut is the gray bit just inside the flange that is bolted to the wall. It threads on the darker piece just inside it. I'm wondering if anyone has any suggestions on how I could get some purchase on this and torque it down.
I've also attached a photo of what the fully assembled throttle looks like (sorry for the low quality, this is all I could fine on my phone ATM.)
RegisteredUser 10-08-2019 11:41 AM
Re: Throttle Wrench
Hard to see that well...
Maybe u-shaped metal clamped with pliers.
Make bottom of u the width of nut
tempest 10-10-2019 09:48 AM
Re: Throttle Wrench
one thing that comes to mind is an oil filter channel lock pliers
IDK if you have enough clearance in there to get a bite though.
https://www.homedepot.com/p/Channell...-209/202247297
Or, Something like this Locknut wrench the open end looks offset and adjustable.
https://www.homedepot.com/p/Gardner-...-301782762-_-N
capta 10-10-2019 01:41 PM
Re: Throttle Wrench
Perhaps a pair of needle nose pliers would do, sticking the points into oposite holes?
Otherwise, over the years I've had very good luck using three screwdrivers to do odd nuts. one on each side and one to turn those two as close to the nut as you can.
RegisteredUser 10-10-2019 01:53 PM
Re: Throttle Wrench
Another thought is to find or create a nick in the nut, then use a screwdriver and light hammer to work it around. Think chiseling...
PhilCarlson 10-10-2019 02:04 PM
Re: Throttle Wrench
I'm completely unfamiliar with that assembly... But I think before I went forcing bits to turn, I'd remove that locking washer and see if the assembly slides out.
colemj 10-10-2019 03:38 PM
Re: Throttle Wrench
That looks like something an old Atomic 4 hand crank handle would fit.
http://www.moyermarineforum.com/foru...1&d=1259692016
Mark
RegisteredUser 10-10-2019 07:32 PM
Re: Throttle Wrench
The nut looks like it is 2 way, turned both directions, not one designed to overrun just one way....ie keep from braking bones.
Im guessing there is some type of packing or sleeve behind it that allows the lever to stay set at adjustable friction.
Whatmake and year is your throttle system might be step 1
RegisteredUser 10-10-2019 07:44 PM
Re: Throttle Wrench
Take good measurements, then hit a big box store
I bet you can fashion a nice wrench for that with a short section of emt conduit and a grinder.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
