1/2 inch sea cocks - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 10-11-2019
Re: 1/2 inch sea cocks
Originally Posted by RegisteredUser View Post
You might be looking at a thru hull and seacock going 30ish years....
A quality bronze thru-hull will last that long, which is why you do it right and never think about it again. There are low end versions that literally recommend inspection/replacement every 5 years.
Jeanneau 54DS
Minnewaska is offline
post #12 of 13 Old 10-27-2019 Thread Starter
Ok so I can put in 3/4 flush Buck Algonqin thru hulls, same tapered flange, just bigger hole. So that is what I am going to do, but... Now a question: I also came across 1/2 NPS thread tap. Wondering if tapping the NPT female side of a ball valve that is currently NPT would work? Would it allow more threads to contact? I am probably going to try it on an old gate valve that I can throw away when done. Just to see if it solves the old "cant mix nps with npt" problem. Anyone done this? Tap is about $24 bucks so this isnt a money saving route unless you could do 3 or 4.
GGardner is offline
post #13 of 13 Old 10-28-2019
I would not recut the threads. Just get the proper flanged adapter for the inside.
Jeanneau 54DS
