Tavana 33 offshore voyaging capacibilities - SailNet Community
 5Likes
Old 10-11-2019 Thread Starter
Hello I am looking for a bigger/most capable boat( even if my current alberg 22 is quite capable from my point of view ! ) I have the opportunity to buy a old Pearson vanguard 33 but it is quite a project a big project and I am looking at a tavana 33 too and at first I did not considered the tavana but after looking on sailboat data I am quite impresse by the displacement of the boat and kind of interessed in the shallow draft options, and the centerboard for more serious sailing ! gives you a nice versatility !
if I understand right you can sail the boat without the centerboard up since there is a long keelish or am I completely wrong and not having the centerboard up would pretty much just be to approach shallow area and motor/ down wind pretty much!?
also wondering if the tavana 33 as any knowed offshore passage to his name or if you would considered it for offshore voyaging and if not why !
thank you !
Ghyiome is offline
Old 10-11-2019
al brazzi
Re: Tavana 33 offshore voyaging capacibilities
You only need the board down to improve up wind tracking,it helps minimize leeway. Foe example racers will go board up wind and raise off the wind and downwind, these differences are sometimes hard to see so down/up can be used for draft control just as well.
albrazzi is offline
Old 10-11-2019
Iirc, these were built in the keys and designed for keys and bahamas sailing.
Many were owner finished. I think the challenge would be in finding one in very good condition, depending on your needs and plans.
RegisteredUser is online now
Old 10-11-2019
roverhi's Avatar
Have a Pearson 35, a slightly newer center boarder designed to the same CCA rating rule. These boats tended to be relatively narrow with long overhangs and short waterlines. Even though they have a short static water line it stretches out when the boat heels so can sail faster than their water line would suggest. These early boats tended to be overbuilt so, given proper maintenance, are more than capable of offshore passages. Some say they are much better in survival conditions because the shallow draft won't trip the boat causing it to roll in breaking waves. They have much smaller interiors than a modern boat of the same water line but that only matters if you have to pay slip fees based on O/A length as long as the boat works for you. .
I've sailed my boat to Hawaii solo. Easy passage with good manners in a mostly DDW passage. Averaged 140nmpd running wing and wing in lighter winds than are usual for this region. Only put the board down for going hard on the wind which is virtually never. This is my second C/B boat and used the board little in either one. The board does reduce leeway hard on the wind but the long keel underbody doesn't need the board once you ease the sheets. When boat was in SF regularly saw winds gusting past 30k and was in 40k winds once.
roverhi is offline
Old 10-12-2019
Master Mariner
capta's Avatar
We use our board literally all the time, sailing and as liveaboards while at anchor.
Your board not only reduces leeway going to windward, but depending how much you let it down it affects trim as well, especially as you begin reefing!
Going down hill it reduces rolling and adds a bit more rudder control. Much of the time we sail with 14 of 24 turns down, heavily reefed main and Yankee Jib and we can walk away from the helm for short periods, as she balances out so well. But make no mistake, when I really want to punch my way up hill in 25+ knots of breeze, it's no small thing to go from a 6' draft to a 10.6' draft!
At anchor, dropping the board in a rolly anchorage will definitely reduce rolling. Fix and learn to use your board and you may never buy a fixed draft boat again.
albrazzi likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
Old 10-12-2019
roverhi's Avatar
Don't know how your board and it's housing were built and designed, but using the board like you are in C/B boats I've owned would drive me bonkers. Would venture to say that most center board wells allow a lot of slop to keep critters from hanging up the board. That also allows them to swing from side to side as the boat rolls and banging. Our board does not bang going to weather but the board makes it's presence felt and heard when you crack off and the boat begins to roll. On a broad reach or DDW the board bangs mercilessly. In our mil pond flat marina, the passing 5 mph power boats cause the board to announce its presence. Other than full up or going to windward the board bangs around. Just want you to be aware that Capta's experience with their broad isn't typical.
roverhi is offline
Old 10-12-2019
Master Mariner
capta's Avatar
Originally Posted by roverhi View Post
Don't how your board and it's housing were built and designed, but using the board like you are into C/B boats I've owned would drive me bonkers. Would venture to say that most center board wells allow a lot of slop to keep critters from hanging up the board. That also allows them to swing from side to side as the boat rolls and banging. Our board does not bang going to weather but the board makes it's presence felt and heard when you crack off and the boat begins to roll. On a broad reach or DDW the board bangs mercilessly. In our mil pond flat marina, the passing 5 mph power boats cause the board to announce its presence. Other than full up or going to windward the board bangs around. Just want you to be aware that Capta's experience with their broad isn't typical.
This is my 3rd 'board' boat any banging has never been a problem. We may be "lucky" but there are lots of ways to silence a board, if you wanted to. Talk to a few boat yards of quality, (probably not any in Hi) but with the internet.....
capta is online now
Old 10-12-2019
chef2sail's Avatar
In the many years I’ve owned Haleakula, I’ve never heard the board ....ever.
Ours is pretty heavy
It was our secret weapon for pointing, allowed us to go to 21 knots of wind before reefing.
We’ve never had any negatives with critter in the trunk any more than critters in the thru hulls.
capta likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
Old 10-13-2019
Administrator
Jeff_H's Avatar
Back to the original question:
Originally Posted by Ghyiome View Post
Hello I am looking for a bigger/most capable boat( even if my current Alberg 22 is quite capable from my point of view ! ) I have the opportunity to buy a old Pearson Vanguard 33 but it is quite a project a big project and I am looking at a tavana 33 too and at first I did not considered the Tavana but after looking on sailboat data I am quite impressed by the displacement of the boat and kind of interested in the shallow draft options, and the centerboard for more serious sailing ! gives you a nice versatility !
if I understand right you can sail the boat without the centerboard up since there is a longish keel or am I completely wrong and not having the centerboard up would pretty much just be to approach shallow area and motor/ down wind pretty much!?
also wondering if the Tavana 33 as any known offshore passage to his name or if you would considered it for offshore voyaging and if not why !
thank you !
I will start by saying that there is a huge difference between a boat that someone managed to take offshore and make a reasonable passage on, vs. a boat that makes a good offshore cruiser. Whether or not someone successfully made an offshore passage or not, the Tavana would make a very poor choice for offshore cruising.
(This is from comments that I made on an earlier discussion of Tavanas) I don't have time to do a detailed analysis, but as a broad generality a boat that is intended to go offshore should have several key traits; lots of stability, a hull form and rig that can quickly adapt to a broad range of wind speeds and sea states, generous carrying capacity, and robust construction. The Tavana has none of these with the possible exception being robust construction, and even that is also a little questionable.
While I am a big fan of keel/centerboard boats for their flexibility in being able to sail in shallow venues yet potentially offering good performance if well designed, they do require greater care in designing them if they are going to sail well and be seaworthy. It is much harder to obtain enough stability in a keel/centerboard boat than it is in a deeper draft boat since the vertical center of gravity of the ballast is by necessity closer to the vertical center of buoyancy of the boat. The net result is that there are only some mix of three ways to create enough stability in a keel/centerboard boat; 1) Increase form stability (i.e. catboat), 2) add more ballast (typically in the 40 to 55% range) and 3) have a little more draft so that the ballast can be located lower below the boat.
The design of the Tanana does none of these, having minimal form stability, being very short on ballast (around 25%) and having a very minimal draft. Making matters worse this is a very heavy displacement boat on a narrow short waterline resulting in a deep canoe body further lowering the vertical center of buoyancy and reducing stability.
This is a high drag hull form that would require a comparatively large amount of sail area to be able to sail decently in any conditions as compared to a more moderate drag hull form, but the design lacks adequate stability to carry a large enough sail plan for decent light air or safe heavy air sailing. It is also a hull form that is likely to roll and pitch through large angles and snap at the end of the roll for an uncomfortable motion comfort.
The best of the Keel/centerboard cruising boats actually had a shallow fin keel and skeg hung rudders and with the centerboard emerging from the fin keel. This allows the ballast to be located lower and reduces wetted surface and drag. They typically have moderate displacements in the L/D range around 200 to 260 so that the canoe body is not as deep as well.
Stability is required to carry an easy to handle rig that can quickly adapt to changing conditions. In the case of the Tavana, the rig is a low aspect ratio ketch rig, while that keeps the sail plan lower and so helps on a boat with so little inherent stability, it also means a less efficient sail plan that needs much greater sail area than a more efficient sail plan to help the boat sail well. That makes the boat harder to sail and makes it much harder to adapt to a broad range of conditions.
The small water plane of the Tavana would greatly limit the percentage of her overall displacement that could be used for carrying stores, equipment, and consumables.
As a side note, in and of itself displacement does nothing good for a boat. It does not make it more seaworthy, or improve motion comfort. It does not add carrying capacity. It does not make a boat more stable or more robust. It only makes a boat harder to handle, more expensive to build and operate, and perform more poorly.
The robustness issue is harder to explain. Reportedly the Tavana has a very heavy hull layup. But the glass work is crudely done with a larger percentage of non-directional fabric (mat) which does not inherently result in a particularly strong hull, and tends to produce a hull that is more prone to fatigue over time. These boats lack internal framing to help with hull stiffness and reduce fatigue and increase impact resistance. It is my understanding that the early Tavanas had wooden decks and cabins, which can have equal strength to a glass deck and house, but generally do not.
To address your specific case, I would doubt that you can sail the Tavana above a beam reach without the centerboard at least partially down. Without the centerboard down and with such a small effective keel area and inefficient shape, I would expect this boat to make huge amounts of leeway, and roll mercilessly without the damping that the centerboard provides.
Also, for what it worth, as a former Pearson Vanguard owner, the Vanguard would also be a very poor choice for use offshore.
Respectfully,
Slayer and mrWinter like this.
Jeff_H is online now
The Following User Says Thank You to Jeff_H For This Useful Post:
Slayer (10-14-2019)
Old 10-13-2019
Master Mariner
capta's Avatar
Respectfully,
Every time I read one of your informative posts regarding a specific boat like this, I think of how we could have designed the perfect cruising boat together. Timing, forever timing.
Nice post!
capta is online now
The Following User Says Thank You to capta For This Useful Post:
Jeff_H (10-13-2019)
