Sailing failures - Page 5 - SailNet Community
 146Likes
post #41 of 110 Old 10-17-2019
Re: Sailing failures
Originally Posted by Minnewaska View Post
This is a problem, as it's different for different manufacturers. Even the time before expiration can differ. Our Kidde are good for 12 years, I believe. and the date of manufacture (not expiration) is embossed on the bottom of the cylinder.
Ironically, I replaced them all a few years back and they almost immediately had a recall, so I got all new for free, about a year later. My boat wasn't 12 years old at the time, but the date on the extinguishers was a couple of years older than than the boat. I bet this is not uncommon, when you buy them off the shelf.
Another best practice is to remove a powder extinguisher from it's mounting bracket, at least annually, and rock it around a bit to insure the powder doesn't settle too much.
Hm, this is a secondary concern, the primary being that the fire extinguisher works when needed. But: if there is no expiration date visible on the unit. how does the CG determine whether to fine you for it being expired?
MastUndSchotbruch is online now
post #42 of 110 Old 10-17-2019
Originally Posted by PhilCarlson View Post
Lesson passed along from a friend who discovered the 'settled powder effect' while fighting a fire. His habit had been to check the gauge only. The extinguisher discharged, but not nearly as much powder as it should have. (happy ending regarding the fire)
Since then he has taken to periodically tapping on the cylinders with a rubber mallet. I immediately applied that technique to my extinguishers and could absolutely hear and feel the difference as the powder loosened up. It's now a regular practice.
I have done this occasionally but never noticed anything moving inside. Does that mean everything is just beautiful, or the powder is so much settled that nothing will budge it?
post #43 of 110 Old 10-17-2019
Minnesail's Avatar
Originally Posted by Minnesail View Post
I was on a Delphia 37 that had the propane shutoff UNDERNEATH the oven. Like, not on a panel below; you actually had to reach in a ways underneath the oven. Itís a Polish design. Insert ethnic joke here. Otherwise it was a lovely sailboat.
Bet you wouldn't insert that joke if there were a half dozen 6ft Poles sitting at your table. That's likely the case on an international sailing forum. No?
It was a cheap shot to be sure, my apologies to the Polish readers of this forum. Perhaps being of Norwegian descent Iím a little too comfortable with deprecating national jokes. (Ole, Lena, et al.)
And more directly, I doubt the position of the shutoff was the choice of the good designers at Delphia. The rest of the boat, both sailing and accommodations, was well thought out.
Catalina 22
on a starboard tack
Minnesail is online now
post #44 of 110 Old 10-17-2019
bell ringer
Don L's Avatar
I've never read a single great adventure salty story scare the crap out you super brave facing the elements because everything went wrong and I almost died so I wrote a book to make money off it by making it a great sea story account BOOK!
Reading sailing forums the past 12 years or so I learned all I needed to know about those stories - don't be an idiot and if you aren't don't have a schedule that turns you into one
Whalerus likes this.
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
post #45 of 110 Old 10-17-2019
davidpm's Avatar
This is an epic story that will keep you entertained for a few hours.
https://www.sailnet.com/forums/gener...-atlantic.html
I met Doug, Interesting guy. He bought another boat even bigger after losing Triumph.
davidpm is offline
post #46 of 110 Old 10-17-2019
Old soul
MikeOReilly's Avatar
Great book idea!
Title: My Big Scary Sailing Story
Subtitle: My great adventure salty story scare the crap out me super brave facing the elements because everything went wrong and I almost died
bshock, Minnesail and Whalerus like this.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #47 of 110 Old 10-17-2019
Why would someone write a book about a failed attempt at something, unless you failed spectacularly it would not be a very interesting story I think one would lick their wounds move back to shore and try to get on with their life.
I do remember someone who wrote about his adventures and I think shared it here a few years ago. He was self-deprecating saying how he was short and overweight and not mechanically inclined. Still, he took sailing lessons, bought a boat, fixed it up and took off cruising. He made it to The Sea of Cortez from San Francisco sailed for a couple of months and considered it enough of a success to write a book about it.
I think the stories of successes are often ones of multiple failures and perseverance leading to success.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #48 of 110 Old 10-17-2019
Bill Bryson wrote a book called a " Walk in the Woods" which was later made into a movie Starring Robert Redford, Nolte and Emma Thompson.
I think Bryson, only got 200 miles along the trail before calling it quits. Failure turned into Success?
wsmurdoch and Minnesail like this.
tempest is online now
post #49 of 110 Old 10-17-2019
Minnesail's Avatar
Good example! I never saw the movie, but the book was hilarious. We need a similar sailing book.
Catalina 22
on a starboard tack
post #50 of 110 Old 10-17-2019
Aquarian's Avatar
On the topic of dry chem fire extinguishers. They should be turned upside down and shaken or spanked a couple times a year. The chemicals settle in the bottom and pack down over time preventing them from being expelled properly. Sounds goofy, but tis true - I worked for a fire safety service co once upon a time.
SanderO likes this.
Aquarian is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
VtSiren17
