Perkins diesel glow plugs - SailNet Community
 2Likes
  • 1 Post By Minnewaska
  • 1 Post By boatpoker
post #1 of 5 Old 10-21-2019 Thread Starter
cdy
My Liberty 28 has a Perkins that runs fine - recently have had a heck of a time starting it - bought the boat in April - PO had jury rigged a glow plug button - with diesels I have had in the past usually you hit a button or turn the key halfway to warm glow plug - with this engine he has a wire that you attach to the house battery - through a fuse to a what I believe is an attachment point on the glow plug - leave it on for 5 minutes and engine starts right up - then disconnect wire - engine will start up without out it once it runs for a few minutes - but there must be a short in the wire now - no spark so no warming the plug I guess - am I understanding this correctly?
cdy is offline
post #2 of 5 Old 10-21-2019
midwesterner's Avatar
Re: Perkins diesel glow plugs
Rather than a short, I'd say it is a broken connection. There may be a break in the wire, or a corroded connection. You can run a simple continuity test, a current test, or run a jumper wire from the battery to the glow plug (which is basically what he did) and see if it begins working again. If so, it means that there is a break in the wire. You can do what he did, and run a new wire, or, it might be a good opportunity to rewire it back through a push button at the control panel.
midwesterner is offline
post #3 of 5 Old 10-21-2019
No glow plug takes 5 minutes to be ready for ignition. They only need to get hot enough to aid the first combustion cycle, not warm up the whole cylinder. Any chance this is powering a block/cylinder warming pad?
PhilCarlson likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 5 Old 10-22-2019
Dirt Free
boatpoker's Avatar
What Minne said.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #5 of 5 Old 10-22-2019
Old as Dirt!
svHyLyte's Avatar
The Perkins Diesel utalizes a "flame start" system for cold weather starting assistance. The "glow plug" actually heats a drip of fuel until it ignites, which takes a few minutes. When the fuel ignites, one can actually hear a it--a somewhat "whomp" sound upon which turns the ignition key to the start position and, most often, the engine will spin right up. For more on the subject see "Perkins Cold Start Wiring" on the Cruisers Forum.
FWIW...
svHyLyte is offline
