Converting to internal halyards - Page 3 - SailNet Community
 6Likes
post #21 of 22 Old 10-24-2019
Re: Converting to internal halyards
Originally Posted by Minnesail View Post
....My main does *not* fall into the stackpack unless it's pretty much completely de-powered. Should it?
Not if itís powered up, it wonít. If the wind is forward of the mast, can you ease off the boom, so itís essentially into the wind, even if the boat is not? Downwind, Iíd likely center the boom and run near the slip. May not work on your rig.
Jeanneau 54DS
Minnewaska is offline
post #22 of 22 Old 10-24-2019 Thread Starter
Minnesail's Avatar
Originally Posted by jephotog View Post
I can't tell from the pictures what is going on here but this looks to me as though a deck mounted spring loaded blocks or under mast plate with blocks should be in this setup to transition from vertical to horizontal.
Um, the lines exit the mast not quite horizontal, maybe 20ļ down. So they donít enter the deck organizer quite straight. Is that what youíre talking about? They run fine, they donít bind at all.
jephotog likes this.
Catalina 22
on a starboard tack
Minnesail is offline
