Considering Catalina 38 - Page 2 - SailNet Community
 14Likes
post #11 of 27 Old 10-24-2019
chef2sail's Avatar
Re: Considering Catalina 38
No condescension intended Chef.
I fail to see how you could run the halyards to the cockpit without winches though - It's a 38' boat. Were you thinking about removing the existing ones and remounting them aft?
Anyway you figure it, it's going to be an expensive job.
Like I said in all my posts I am not sure the configuration of a their particular Catalina 38, and what’s under the dodger ( assuming they have one).
Our C&C 35 MKIII came with 3 - 2 speed self tailing Barients under the dodger. It was simply doing the blocks, clutches, horns, and Sta-set. If their Catalina 38 only had 2 , one on either side , clutches and horns would be enough to accomplish what they want to do easily as well as keep it organized and neat.
If they don’t have that and HAVE to purchase winches like I said in previous posts it adds $1500-$2000 to the equation. In a new boat I don’t consider spending $1500 a huge amount to effectively make such a significant change.
That way they could save some costs and my projection of $1500 sans sales on equipment would hold . I believe we agree then.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #12 of 27 Old 10-24-2019
JimMcGee's Avatar
You can cut the cost of the Sta-Set by about half if you're not in a hurry. West Marine does 40% off sales on line about once per quarter.
Lewmar #16 two speed non-self tailer's are $579 new (WM prices). Figure half that used at Bacon's.
There's no need to figure out the turning block setup. Just walk down the dock, find a Catalina and take a picture of the setup. They've all be done the same way for at least 20 years now and it works well, so no need to re-invent the wheel.
Finally a keel stepped mast isn't all that unusual. If you don't see something obvious for mounting a turning block in Garhauer's catalog give them a call. I'll guarantee they have something or they can make something for you because they've done it before. Their prices are reasonable and they've got very good customer service.
catalina38.org's web site is up and running, but it doesn't look like there's a lot of activity. A lot of these groups are moving onto Facebook now, so I'd try searching there. I can guarantee you're not the first person to do this project. That's one of the upsides of owning a Catalina. Any boat project you're thinking about has been done and somebody's written up a step-by-step how-to guide with pictures and posted it online.
Best of luck with her, Jim
Currently Boatless
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #13 of 27 Old 10-24-2019
Minnesail's Avatar
When I ran my lines back to the cockpit I was able to remove a winch from the mast that was no longer needed. Maybe they can do the same.
JimMcGee likes this.
Catalina 22
on a starboard tack
Minnesail is offline
post #14 of 27 Old 10-24-2019 Thread Starter
Great Lakes Sailor
Thanks everyone! You've both given me a lot to work with and think about. I'm still keen on this boat. We don't own it yet. I think we should sail for a season without any changes and see how we fare. Learn the ropes, as it is. I'm glad to know what it takes to get it done, before we make an offer.
Jenksie is offline
post #15 of 27 Old 10-24-2019
chef2sail's Avatar
That’s a great idea.
Running you lines to the cockpit will be a great improvement and increased safety issue.
Good luck on getting the boat. Check in and let us know how everything is going.
Jenksie likes this.
Parkville, Maryland
Our blog-
post #16 of 27 Old 10-25-2019
SanderO's Avatar
I have a self tailer on the coach roof (both sides) and use it for the main halyard and topping lift. Head sail's halyard is at the mast and it has a self tailing wind and line stopper/clutch.
I do sometimes use the primary winch for the main halyard with no issue and more room to work and better visibility of the sail... then from under the dodger.
Shiva is deck stepped with lines led aft OEM.
It has:
2 stainless slotted angles on each side of the mast to which blocks are attached.
Then there is a 2 double sheave deck organizer a few few aft of the mast base turning blocks
The dodger has an opening on each side for the rigging lines
under the dodger are 2 double attached line stopper/clutches on each side
and finally a winch on each side.
The rigging led to the cockput is:
main halyard
topping lift
2 forward reef lines
2 aft reef lines
vang
outhaul
Jenksie likes this.
pay attention... someone's life depends on it
SanderO is online now
post #17 of 27 Old 10-25-2019
ASA and PSIA Instructor
Originally Posted by roverhi View Post
I’ve sailed on two boats with single line reefing and both sucked big time. The friction took a lot of muscle to haul the reefing line in, things hung up on the reef requiring trips forward to clear, the sail didn’t trim well because of friction caused inability to haul the leech taut and there is a league or two of line you have to pull in. To be fair the boats lived in light air areas and the attempts to reef could have been the first time it was ever used so not properly sorted out. In any case, never considered single line reefing....
FWIW the single line reefing on my Pearson 31-2 works like a charm. While there is friction in the reefing line system, it isn't much more than I find present in the clew reefing line in a typical two line system, and as the reefing line leads to a cabintop Lewmar 30 winch, any friction is of no significance.
See an example here:
https://youtu.be/Bg5r3_45up8
Minnesail and Jenksie like this.
sailingfool is online now
post #18 of 27 Old 10-25-2019
Minnesail's Avatar
That sounds very wise.
Jenksie likes this.
Catalina 22
on a starboard tack
post #19 of 27 Old 10-27-2019 Thread Starter
Great Lakes Sailor
This will reveal my inexperience in boat buying, but here goes. I realized the Catalina 38 in question has a shoal draft (plus the aforementioned cruising rigging). Does anyone have experience racing this model?
The guys I will race against are sailing boats like a Beneteau 35, S2 9.1 and a Catalina 30TM
We race on Lake Michigan with PHRF handicap in Jib & Main section (until I get a spinnaker situated). And you can assume my team has better sailors. lol.
The Catalina I'm looking at is so well maintained and updated, it's hard for me to pass by.
Jenksie is offline
post #20 of 27 Old 10-28-2019
The Catalina 38 started life as a Yankee 38. Catalina got the molds when Yankee went under. A beautiful boat, but designed as an IOR racer/cruiser. Some stability issues downwind. I think halyards lead aft are often over rated and sometimes just lead to clutter. For example, to me, bringing halyards back on roller furling headsails and roller furling main aren't worth it. There is increased friction by bringing back. As suggested, try it for a season and sea what you think. I am probably totally wrong but never in doubt.
zzmeyer is offline
