Frozen holding tank - Problem? - SailNet Community
 10Likes
post #1 of 32 Old 11-13-2019 Thread Starter
So, I am scheduled for haul out today. Normally the procedure is to stop by to dock for a quick pump out first. I have a feeling that won't work this year with today's temperature of 15F / -10C. So it looks like I may have a block of crap in my tank for the winter. What catastrophe I am in for? Another option may be to reschedule to next week when it's above freezing.
Ninefingers is offline
post #2 of 32 Old 11-13-2019
Sailor
Gladrags1's Avatar
Re: Frozen holding tank - Problem?
Shouldn’t be a problem unless the tank is full and it splits. These tanks are strong to resist the pressure from pumping stuff in to them when the vent is clogged. I think you should be ok.
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #3 of 32 Old 11-13-2019
Silly Question ...Can't the yard pump it out for you? or reschedule.
tempest is online now
post #4 of 32 Old 11-13-2019 Thread Starter
They don't have mobile pumps that I am aware of. Only at fuel docks.
post #5 of 32 Old 11-13-2019
Do not panic. Usually the water temperature insulates interior "liquids" to a degree. It's when the boat is pulled out that the big freeze begins. For the time being you could flush a jug of heated RV antifreeze into the mix. Maybe setup an electric heater ABOVE the tank level. If it's cracked, thawing it out could pose a shock hazard as well as a sh*t show so keep an eye on it. If you want to do a trial run borrow your neighbors shop vac and hook it into your deck fitting. It's an old northerner trick that does work in a pinch. Good luck
"And furthermore I do not care for the way you are running this ship".
Northeric is offline
post #6 of 32 Old 11-13-2019
Buckets could be an option.
Id probably go ahead and spring for lids too...
RegisteredUser is online now
post #7 of 32 Old 11-13-2019
Old soul
MikeOReilly's Avatar
I assume you’ve already ruled out getting a heater in there and warming up the tank beforehand? Perhaps dumping antifreeze in on top of the crap might be a good idea — you probably have to do this anyway to protect the head valves.
It’s probably not a problem as long as the tank isn’t very full, but personally I’d feel a lot better getting it out.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #8 of 32 Old 11-13-2019 Thread Starter
I've only got 4 more hours before haul, so a heater may not cut it. It's possible it's not frozen, (haven't headed to the marina yet). Given the snow and ice on the docks, I wouldn't be surprised if they stopped doing pump outs for safety reasons. Still 150 boats in the water. I'm sure possible frozen slings on the travel lift don't make them happy either.
post #9 of 32 Old 11-13-2019
Old soul
Yuck. I hate hauling out in the snow and cold. One of the joys of Canadian boating...
Four hours might be enough time to warm up the muck. But as you say, they may have already shut off the pump out plumbing.
Good luck with it all.
BLOG:
post #10 of 32 Old 11-13-2019
chef2sail's Avatar
How about putting antifreeze into the holding tank.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
