Popsicle Stick Bulkhead Templates - SailNet Community
 8Likes
  • 2 Post By MarkofSeaLife
  • 2 Post By Arcb
  • 1 Post By boatpoker
  • 1 Post By Minnewaska
  • 2 Post By Capt Len
post #1 of 7 Old 12-06-2019 Thread Starter
Kielanders's Avatar
You old salts probably already know this, and I can't remember where I read this online, but there was an article I found that mentioned how to make precise bulkhead templates.
It basically involves using a hot glue gun and a bag of popsicle sticks, both of which you can find at any craft store.
There's no technique other then heading into the hull and gluing them together following the contours of the area you're looking to match.
I would occasionally tack every 6th stick to the hull to maintain the shape of the outline.
I did two large full beam bulkhead templates in about 10 minutes, and just finished cutting and test fitting one bulkhead in about an hour.
I'd read books and watched videos about using a story pole, scribing sections with scrap lumber, scribing pieces of cardboard, or using the old bulkheads (depending on how cleanly you can cut them out), but then stumbled on this.
For anyone out there pulling their hair out looking for a straight forward idiot proof way to get a precise shape mapped in a difficult confined space, I can testify that this is working great for me.
Kielanders is offline
post #2 of 7 Old 12-06-2019
Moderator
MarkofSeaLife's Avatar
Dock
Re: Popsicle Stick Bulkhead Templates
That's how my whole boat was made!
RegisteredUser and Kielanders like this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #3 of 7 Old 12-06-2019
Moderator
Arcb's Avatar
It works, I have a full set of Cal 21 templates in my garage. Cedar strips instead of popsicle sticks, but same idea.
oysterman23 and Kielanders like this.
Arcb is offline
post #4 of 7 Old 12-07-2019
Dirt Free
boatpoker's Avatar
I buy 1X4's aand cut them into 1/4" strips. Had a glue gun onboard since the early 90's. Less than $2 at Dollarama
Kielanders likes this.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #5 of 7 Old 12-07-2019
Same method used to pattern a teak deck.
Jeanneau 54DS
Minnewaska is offline
post #6 of 7 Old 12-07-2019
Door skins are cheap. Cut into strips. (3 or 4" ?) Fudge curves and cut with tin snips .Glue.. cross strips for integrity. Label position and helpful info.
Capt Len is online now
post #7 of 7 Old 12-07-2019 Thread Starter
Kielanders's Avatar
Thanks guys, I just thought I post my experience because a bunch of SailNet threads usually pop-up for me on Google searches for sailboat stuff - just never stumbled across one like this. So, I figured I throw it out there in case someone 10 years from now is pulling their hair out like I was.
