Hull Insulation Paint - SailNet Community
 5Likes
post #1 of 11 Old 12-16-2019 Thread Starter
Kielanders's Avatar
I have the interior gutted, and had a recommendation from a professional marine coatings guy to use a ceramic latex hull insulation paint.
Apparently it's applied with an airless sprayer in three coats, with a total build-up to ~30 mils.
He mentioned that it also helps controls condensation and provide sound deadening.
Condensation control is my main objective with any coating, after protection of the raw hull.
I'm attaching two spec sheets from the product, and a link to the manufacturers website
The stuff certainly sounds excellent, but seems to be primarily used in on commercial vessels.
Have any of you had any experience with this?
Thoughts?
Manfacturer Website: Marine | Advanced Coating Solutions
Kielanders is offline
post #2 of 11 Old 12-16-2019
Re: Hull Insulation Paint
All those marketed to consumers for automotive use (NASA, bubbles) have turned out to be of insignificant value for thermal insulation compared to any amount of foam sprayed on the inside.
But then I never came across it being applied to gain that much thickness.
So I won't naysay it out of hand, but remain skeptical by default.
If convincing reports don't emerge here, my next steps would be actual testing with a sample sprayed around a sheet metal box
or talking to past customers.
Kielanders likes this.
john61ct is online now
post #3 of 11 Old 12-16-2019
Oh, looked back for the thickness.
"30 mil" is not 30mm.
So my skepticism has increased by the same proportion.
A professional spray job on the hull's interior will provide actual thermal insulation.
post #4 of 11 Old 12-16-2019 Thread Starter
Kielanders's Avatar
Yeah, it's 30 mils, and I have trouble seeing how much R value that would have, assuming one even uses the concept of R Value in a marine environment.
However, if it was enough to moderate condensation, it would still be of interest to me.
Thanks!
post #5 of 11 Old 12-16-2019
Hypothetically, if condensation were reduced an average of 20%, would the extra cost of the special coating be worth it to you?
post #6 of 11 Old 12-16-2019
Master Mariner
capta's Avatar
I believe the prep for a paint job like that would be prohibitively expensive and/or time consuming. If some coating like that was of value in this application, I would assume it would be an option when ordering a new boat, especially in the top of the line boats. If I were going to do something like that I'd research neoprene/hypalon in paint form, which I used for a deck coating on a boat. Worked very well.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #7 of 11 Old 12-16-2019
Ceramic paint has been around for ten or twenty years now. It's supposed to work, surprisingly.
Generally, I don't like paint on a boat, because paint eventually chips, peels, etc, and needs to be redone. Imagine the nightmare of having to redo it. I'd research how long it lasts.
SanderO and Kielanders like this.
Jeanneau 54DS
Minnewaska is offline
post #8 of 11 Old 12-16-2019 Thread Starter
Kielanders's Avatar
90% of it will be concealed when the new interior goes in. I sanded down to glass whatever 40 year old paint was used when the boat was made, and am in the process of installing the 7 new bulkheads.
I assumed the exposed glass should be coated, and was going to use a chlorinated rubber paint made by Pettit, which I understand has been around a long time and has a good track record for a variety of applications.
I did notice while doing the sanding, that the parts that remained painted either did not condensate, or condensated significantly less than the unpainted portions - so my thinking was that at least some sort of coating is necessary.
post #9 of 11 Old 12-16-2019 Thread Starter
Kielanders's Avatar
Originally Posted by capta View Post
I believe the prep for a paint job like that would be prohibitively expensive and/or time consuming. If I were going to do something like that I'd research neoprene/hypalon in paint form, which I used for a deck coating on a boat. Worked very well.
It was, and dirty too!
Thanks for the tip on the neoprene/hypalon.
post #10 of 11 Old 12-16-2019 Thread Starter
Kielanders's Avatar
He hasn't sent me the quote yet, but I'll let you know.
When I was sanding down the interior, I noticed a significant difference in condensation on the painted vs. unpainted portions - so I'm convinced I ought to have something, just maybe not top of the line technology.
He's a nice guy and well thought of, and he knows I don't have a status 'yacht', so we'll see where the numbers land.
