NO PFDs - SailNet Community
 34Likes
post #1 of 51 Old 12-21-2019 Thread Starter
NO PFDs
Delivering down the ditch and I've noticed between Morehead City and South of Myrtle Beach all these guys (mostly) blasting around in their jonboats/Boston Whalers/Carolina Skiffs all bundled up for the cold (30s,40s) and I didn't see one PFD. The vast majority were out solo. All it would take was a sudden turn or hit a wake unexpectedly and Oops, in you go. Water temps are in the 40s; exhaustion time is 30-60 min and if you're weighed down with heavy winter wear, good luck. At least I understand why the CG stats on marine fatalities show most were in small motorized craft.
Not a lecture just puzzled. When I singlehand I'm wearing. And with crew if the water temps are down I don't care how nice it is; it's the cold water that'll get you.
sailordave is offline
post #2 of 51 Old 12-21-2019
overbored's Avatar
Re: NO PFDs
maybe they are wearing a type III flotation jacket
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 51 Old 12-22-2019
Old soul
MikeOReilly's Avatar
Re: NO PFDs
What's the water temperature? If it's as cold the the temps you mention, and an event happens more than a few miles offshore, then one has less than 30 minutes to get out. Hypothermia will start shutting down your muscles far sooner in water close to freezing.
When sailing Lake Superior we used to say, somewhat morbidly, that all a lifejacket does is allow the CG to find the body.
P.S. I always wear a lifejacket, even though I now cruise the cold waters of Newfoundland. But I never go out alone.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #4 of 51 Old 12-22-2019
Re: NO PFDs
Excellent, our species needs more Darwin effect at play thinning the herd
john61ct is online now
post #5 of 51 Old 12-22-2019
hpeer's Avatar
Re: NO PFDs
^1+
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
post #6 of 51 Old 12-22-2019
Re: NO PFDs
A guy fell off his center console, in Block Island Sound a few years back, exactly how you describe. No PFD. The boat was in gear, but trolling slowly. He tread water for 11 hrs and was rescued. No one knew he was overboard, until his boat drove up on the beach, hour later. Water temps were mid 70s and it was considered a miracle. In the 40s you would not successfully tread water for more than 15 mins Iím sure, as your muscles stiffen.
Jeanneau 54DS
Minnewaska is offline
post #7 of 51 Old 12-22-2019
Re: NO PFDs
And BTW, I've read that inflatable PFDs don't in cold water. Haven't tested it myself, though.
22catcapri is online now
post #8 of 51 Old 12-22-2019
Lake Sailor
cb32863's Avatar
Re: NO PFDs
Could you please cite your source for this? The sailors that race through the Southern Ocean must be using non-functional PFD's then with a false sense of security.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is online now
post #9 of 51 Old 12-22-2019
hpeer's Avatar
Re: NO PFDs
Just a touch or reality, solo racing in the Southern Ocean probably makes a PFD pretty useless.
When North I use a PDF, but mostly for the built in harness attached to a jack line or hard point, not for the inflation.
overthehorizon likes this.
hpeer is online now
post #10 of 51 Old 12-22-2019
roverhi's Avatar
Re: NO PFDs
Blow up your inflatable dinghy in the early morning before the sun hits it. Check it at noon and it will be grossly over inflated, check it again in the evening and it will be under inflated. Gases expand as they are warmed and decrease as they are cooled. An inflatable vest may not inflate to rock hard when temps are low but it will still inflate. A little addition of air via the oral inflation tube(s) will do the final touch up, but the PFD's will inflate enough to float you even in cold conditions though maybe not in North Pole cold.
roverhi is online now
