Stringer Crack repair under Diesel Engine - SailNet Community
 7Likes
post #1 of 21 Old 3 Weeks Ago Thread Starter
I am way outside my knowledge zone so wondering if anyone has run into this problem. Looking for advice, experience, line of site to potential repair approach/costs.
During survey found a crack on one of the fiberglass stringers under the engine that runs entire length of engine bay (about 3-4 feet). Engine alignment is also a bit off though shaft is straight. That seems easily fixed but will need to deal with the crack at some point. Good news is that mounts are solid and engine doesn't move during backdown and stress testing. There is an appreciable vibration felt in aft cabin floor behind engine area.
This is on a Catalina 470.
Anyone run into this on ANY boat and what was the approach for repair? Need to get an idea of potential cost and time involved.
Thanks in advance!
Greenwave
Greenwave is online now
post #2 of 21 Old 3 Weeks Ago
Re: Stringer Crack repair under Diesel Engine
Assuming there is room, you'd need to disconnect the motor from the shaft and jack it up. Then grind out the crack, fill and glass it back to original or better. Maybe add reinforcement.
The bigger question is why did this happen. Collision? Excessive engine vibration? Severe misalignment?
Obviously, you'll want to prevent it from recurring. However, the cause may reveal other concerns too. Vibration strong enough to crack a stringer would have done a number on the crank bearings and transmission too. They may work today, but excessive wear could shorten service life.
Jeanneau 54DS
Minnewaska is offline
post #3 of 21 Old 3 Weeks Ago
colemj's Avatar
There isn't enough information to suggest an approach. Is the stringer itself cracked, or is just the gelcoat cracked, or is the tabbing loose? Is the stringer hollow, or cored, and what core?
Is the vibration due to this or a bad mount? Both could cause misalignment.
Cost and time could be almost nothing if it is just redoing a bit of tabbing. It could be much more if the engine has to be removed and the stringer replaced or rebuilt.
Mark
olson34 likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #4 of 21 Old 3 Weeks Ago
Moderator
MarkofSeaLife's Avatar
Dock
Are you interested in buying the boat? Or do you already own it?
It feels like you did the survey in the purchase process. If so, I would not proceed further. I dont know nuffin about boat building but theres red flags waving all over the place.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #5 of 21 Old 3 Weeks Ago
Master Mariner
capta's Avatar
+1 on figuring out what caused this problem before you begin repairs.
Is this a structural member? Maybe I got it wrong, but I don't see the reasoning for having a stringer running fore and aft in the center of the bilge, between the engine mounting stringers. Is your hull that thin at that point that it needed the support of a stringer? Is it part of the keel attachment? Could it be a centerboard trunk?
A bit more info and some pics would make it easier to help you.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 21 Old 2 Weeks Ago Thread Starter
Good stuff from many of you. Unfortunately, I don't have a pic just yet. This was found during survey on a Catalina 470. Per early feedback form surveyor, the motor mounts are good and the engine didn't move around during backdown testing. Boat was hit by lightning over a year ago and all electronics replaced. No reported or visible hull damage was found from that. Still waiting on final survey report with pics. I believe this "stringer" does not have a wood core under the glass.
Will report back what is decided.
post #7 of 21 Old 2 Weeks Ago
A 3-4 foot crack, assuming you mean structural and not cosmetic, is a big deal. Tread carefully.
Jeanneau 54DS
post #8 of 21 Old 2 Weeks Ago
Moderator
Dock
He didn't answer the question if he owns the boat or not.
Going on ambiguity of other similar posters he does not own the boat but wants it cheap.... At his risk!
Sea Life
post #9 of 21 Old 2 Weeks Ago Thread Starter
Technically, you are correct. I didn't answer the ownership question but strongly implied since I said this was found during survey... anyways... no I do not own the boat. This is a hot off the press, decision still to be made situation.
MarkofSeaLife likes this.
post #10 of 21 Old 2 Weeks Ago Thread Starter
May have pics from my surveyor later in week. I do believe this is one of THE engine mounting stringers.
more to come...
