Cap/Block/Stop on the ends of the traveler - SailNet Community
 2Likes
  • 1 Post By Barquito
  • 1 Post By chef2sail
post #1 of 10 Old 04-03-2020 Thread Starter
hnash53's Avatar
I have a traveler on the Schock 25. But there is no cap, no block, no stop on the ends of the traveler.
The "car" on the traveler literally goes off the rails when it reaches the end.
I'm looking for suggestions as to what would work as a stop at the ends of the traveler.
From what I can tell, it doesn't look like there ever was something there.
Check out the pics I have attached.
Thanks!!
hnash53 is online now
post #2 of 10 Old 04-03-2020
SchockT's Avatar
Re: Cap/Block/Stop on the ends of the traveler
It is unlikely that there was never a stop on it. Being old finding the correct one could be a challenge. The simple thing to do would be to make something out of a chunk of rubber. (Cut up a hockey puck perhaps?) Pull the last screw out, and replace it with a longer one that can secure your home made bumper.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #3 of 10 Old 04-03-2020
A hitch pin with track drilled horizonally might be an cheap, easy fix
RegisteredUser is online now
post #4 of 10 Old 04-03-2020
Master Mariner
capta's Avatar
If you secured the lines I see in the pics at a point where the car wouldn't come off the track, wouldn't that solve your problem?
However, that said, we sail with the car amidship unless we wish to depower the main or ease the sheet angle for down wind or reaching. Perhaps you should just secure the car amidships until you need to adjust it, then use the lines to do that.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #5 of 10 Old 04-03-2020
Barquito
Barquito's Avatar
I can see scuff marks on the end of the car. Looks like they had something welded onto the track that broke off. I like either of the two previous suggestions. The extended bolt with a rubber bumper of some kind would look better to me.
Something like this might come pretty close to fitting:
https://www.velasailingsupply.com/sc...CABEgJtzvD_BwE
paulk likes this.
Valiant 32
Barquito is offline
post #6 of 10 Old 04-03-2020
chef2sail's Avatar
We have the Schaefer’s . Usually used for sail tracks for the job, but may fit the bill
https://www.velasailingsupply.com/sc...iABEgL1kvD_BwE
https://www.westmarine.com/buy/schae...iABEgIDj_D_BwE
https://www.sailrite.com/Sail-Track-...SABEgI9uvD_BwE
SanderO likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #7 of 10 Old 04-03-2020
JimsCAL's Avatar
Here's what the track stops look like for a Schaefer traveler. Note there are multiple sizes of Schaefer tracks, two before about 1987 and two after. Measure.
https://www.rigrite.com/Travellers/S...haefer_118.php
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #8 of 10 Old 04-03-2020 Thread Starter
hnash53's Avatar
Hey there you guys... wow... great suggestions!!!
Thank you all for all of the info and for providing links to possible solutions.
Again, you guys are great... much appreciated.
Hal Nash
Waldport OR
post #9 of 10 Old 04-07-2020 Thread Starter
hnash53's Avatar
Here are a couple of pics of my "custom" traveler end stops.
Again.. thanks for all the suggestions to help me out on this.
post #10 of 10 Old 04-09-2020
SanderO's Avatar
I set up the blue lines so I can control the position of the mainsheet on the traveler track.
pay attention... someone's life depends on it
SanderO is online now
