Schaefer 70-17 camcleat with 77-18 fairlead - SailNet Community
post #1 of 6 Old 04-04-2020 Thread Starter
Anybody know how these go together? You would THINK that an accessory intended for a product would simply fit. Do I remove the back plate from the camcleat and replace it with the fairlead? The bosses in the fairlead will not fit in the cleat. Do I cut them off? This is ridiculous.
DonScribner is offline
post #2 of 6 Old 04-04-2020
Re: Schaefer 70-17 camcleat with 77-18 fairlead
(Fairlead) Mounts directly to our 70-17 Cam Cleat. Will require (2) #10 RH fasteners.
https://hardware.schaefermarine.com/...oducts_id=3794
So it looks like this is just a fairlead, that does not work with your cam cleat: Schaefer Marine Wire Fairlead f/70-17 with Base 77-18 Color: Black,
WrkrBee is offline
post #3 of 6 Old 04-04-2020
overbored's Avatar
the 70-17 is a plain cam cleat with no fairlead the 77-18 is a replacement base with a wire fairlead you have to switch the bases. the 77-07 is mounted on top of the cam cleat and you should use one or the other not both
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 6 Old 04-05-2020 Thread Starter
I purchased the correct parts.
post #5 of 6 Old 04-05-2020
Seems so, per the packaging. Go back on Schaefer and have "Customer Service" explain. Good luck.
WrkrBee is offline
post #6 of 6 Old 04-05-2020
overbored's Avatar
you remove the existing bottom plate from the cam cleat and replace it with the new bottom plate that has the wire fairlead.
