What would be the modern equivalent of this block? - SailNet Community
post #1 of 12 Old 04-07-2020 Thread Starter
hnash53's Avatar
On this Schock 25 sailboat are several pieces of "Tuphblox" rigging.
Pictured are a couple of photos of a Tuphblox block used to route traveler lines to a cam cleat.
What would be the modern equivalent of what is pictured here?
Thanks.
hnash53 is online now
post #2 of 12 Old 04-07-2020
SchockT's Avatar
Re: What would be the modern equivalent of this block?
It's called a Cheek Block
This is the modern high tech equivalent
https://www.harken.com/productdetail.aspx?sku=350
But you dont need anything that fancy. Every hardware company makes something similar.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #3 of 12 Old 04-07-2020
paulk's Avatar
Looks like a cheek block. Lots of manufacturers make them.
paulk is online now
post #4 of 12 Old 04-07-2020 Thread Starter
hnash53's Avatar
I've got that exact one... but I don't know how/where to mount it on this boat.
Do you have a pic of the cheek block doing what I need this one to be doing?
post #5 of 12 Old 04-07-2020
paulk's Avatar
You need to remove the block that is there and replace it with the new one. Leave the angled mounting piece on the deck to mount it on.
paulk is online now
post #6 of 12 Old 04-07-2020
SchockT's Avatar
I assume it is a traveler control line? It is a bit odd because I don't see where the line connects to the traveler car, and I don't see any sign of a purchase. It is not clear why it is mounted on the wedge either.
Maybe if you showed us how it was rigged originally it would help.
It may very well be that there is a better way to do it rather than just trying to replicate the old way.
post #7 of 12 Old 04-07-2020
SanderO's Avatar
looks like a "turning block" for the head sail sheet. As others have mentioned they are called cheek blocks.
pay attention... someone's life depends on it
SanderO is online now
post #8 of 12 Old 04-07-2020 Thread Starter
hnash53's Avatar
Yes, it is the traveler control line. A previous owner tied the control lines to the pad eye on top of the car. That may be part of the problem because the lines from the pad eye enter the cheek block at a poor angle and the line binds at that point. Maybe a part is missing that allows for a better way to connect the control lines to the traveler??
post #9 of 12 Old 04-08-2020
RichF28's Avatar
The setup is similar on my boat. If you want to modernize this might do it.
RichF28 is online now
post #10 of 12 Old 04-08-2020
The traveller support and the blocks appear to be okay structurally. I would remove and refinish all the pieces; the results would be impressive.
paulinnanaimo is offline
