Spade Rudders vs. Skeg Hung - Page 2 - SailNet Community
 1Likes
post #11 of 34 Old 11-29-2009 Thread Starter
Sailing Junkie
ehmanta's Avatar
I know that in the Tartan 37, the skeg is bolted on and is engineered to sheer off along with the bottom half of the rudder incase of severe impact, leaving the top half of the rudder to steer with. I have heard of one T-37 experiencing this scenario and returned safely to port with the top portion intact.
ehmanta is offline
post #12 of 34 Old 11-29-2009
baDumbumbum
bobmcgov's Avatar
An advantage of (true, structural) skeg-hung rudders is the way they separate the steering function of the rudder from its support armature. If your shaft breaks (and quite a number of hollow or CF shafts HAVE broken), the skeg keeps the rudder blade attached to the boat. You can affix ropes to the blade and steer w/ winches, if you have to. And if you ground hard, the skeg takes the beating rather than the steering tube, so maybe you'll still be able to turn the rudder. And maybe your boat won't sink because the internal steering tube fractured from the impact.
A spade rudder relies on a single component to both support and turn the rudder. If it fails, you are hosed. OTOH, spades provide much better lift; they can be thinner and smaller (less drag) and yet turn the boat more nimbly. They cavitate less in messy conditions. And by balancing the blade (moving the pivot point aft of the leading edge), they require far less effort to turn: easier on the helmsman/tiller/steering linkages.
On a performance boat, a spade is great. For displacement hulls, I think I'd like the redundancy of a skeg.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #13 of 34 Old 11-30-2009
Administrator
Jeff_H's Avatar
This was my response to an earlier discussion where a fellow wanted to convert a boat from a post hung to a skeg hung rudder that discusses some of points under discussion,
Changing a boat from a post hung to a skeg hung rudder has been done in the past. I once had a commission to design a modification to a foul- handling ketch with a metal sharpie or powerboat style counterbalanced rudder. This rudder was converted to a stern post- mounted outboard rudder with a partial skeg. The project was made easier by a number of things; first of all going to an outboard rudder with tiller simplified much of the process. We didn't need to build a larger rudderpost tube or add internal floor frames. Secondly the boat was a double ender allowing us to add an oak stern post that stabilized the skeg. Lastly the propeller was fully supported with a short skeg. We added a strut and lengthened the propeller shaft.
This approach would not work on a boat with a reverse transom. To do this on a boat with a reverse transom you will need to do an awful of work. You would need to build a new rudder with a larger diameter post. In one of the BB’s, I had run some numbers on the loads on counterbalanced spade vs. a non- counterbalanced skeg hung the torsion loads (in reverse) on the non-counterbalanced required a bigger rudder post than the spade rudder. You would need to find a way to solidly attach the skeg and distribute to loads into the boat. You would probably want to pass a vertical tube through the bottom to the underside of the deck and then build a fore and aft knee and athwartships floor frame. The skeg would be constructed around this post and glassed into the hull. I would not ballast the skeg in any way as will alter trim.
As far as whether this is a good idea or not, I would say it is not a good idea in any shape of form. To begin with the skeg will alter the balance and handling of the boat. In calculating the balance of a spade rudder the rudder does not figure in, only the canoe body and keel are used. But a skeg becomes a part of the lateral resistance. This would move the center of lateral resistance aft probably give you some lee helm. That is not a good idea from a safety standpoint. When you get hit with a puff of wind you want the boat to try to head up rather than head off toward the knock down.
More significant to this discussion is the question, “why would you want to do this? I have been sailing now for over 35 years. This whole business of an inherent advantage of a skeg or long keel over a post-hung spade is hogwash in the real world. Each have some advantage but properly engineered a spade rudder is handier in almost all counts. I have owned or had use of all three types of keel and rudder. I have found that skeg hung rudders have all of the disadvantages of both with few of the advantages of the spade. I have rarely caught a line in a prop or rudder but the worst case of that was a line that was caught in a long keel cutter.
As I have pointed out, the biggest loads on the rudder occur in backing a boat and while skeg hung rudders would logically seem stronger than a spade this is not always the case. To begin with the gudgeons and pintles on many production boats are such that the pin is a single sheer hinge rather than a double sheer hinge to facilitate removal of the rudder. A double sheer hinge is monumentally stronger. It gets worse if there is enough vertical play and the rudder can be driven upward enough to put the pin in bending. The whole strength of the skeg hung rudder is dependent on these hinges.
But beyond the simple mechanics of the hinges, the skeg itself is very difficult to build well. The skeg is one of those chicken and egg things. Skegs were originally molded as a part of the hull but fear that a damaged skeg could sink a boat led to some boats being built with a skeg built as a separate unit and glassed on. That didn’t last long. But the problem with the skeg molded as apart of the hull is that it is very hard to build. Remember you are trying to get a fully saturated glass resin matrix 3 or 4 feet down from the canoe body in a space too small for a man to stand in or other wise reach easily. I have helped out on a boat that had the lower pintle pull loose from the skeg. What we found was that the pintle casting was through-bolted through essentially dry glass with a small pond of resin at the bottom. There was a lot of dry glass and a lot of resin but no GFR to speak of.
The other problem is at the joint between the skeg and the hull. Typically, today the skin of the skeg turns sharply into the bottom of the counter. There is often a lot of layers of glass across the top of the skeg and the reinforcing around the rudder post, but even on some very well built boats there often isn’t any real structure to distribute the large moment at the top of the skeg. You would expect to see ring frames or floor timbers. Often there is only thick glass and that thick glass is flexing constantly. Fiberglass is very prone to fatigue and this is the perfect condition for fatigue, a stiff object pushing up and down perpendicular to the hull surface.
Does this make a Spade hung rudder any better? No, but it can be engineered better than many a skeg hung rudder is actually constructed. I personally like counterbalanced post hung rudders with their lighter steering loads and greater efficiency. I know the old canard about catching pot warps and the fear that they will bend or be damaged, but for the kind of onshore sailing that I do I like them better.
Lastly to better bearings and seals: Harken makes a great series of rudderpost bearings. They are designed for anything from a 30 or so footer on up to very bid boats. At least some of the Whitbread boats used the Harken bearings on their massively loaded post-hung spade rudders. The seal issue is one that relates more to the design of the steering system. If you insist on a wheel with the quadrant below decks or worse yet below the water line, then there isn’t must to help you. But if like me you prefer a tiller (I heard that groan) then it is easy to install a watertight tube between the deck and the top of the rudder post tube. On my Kirby I had a large diameter clear plastic hose inside the hose I had a couple snap ties which were enough to temporarily support the rudder if the rudder head connection failed.
By the way, who ever said that a post hung rudder was cheaper was mistaken. The torque and moment resisting rudder posts on a post hung rudder are far more expensive to build than a strut and its gudgeons and pindles.
Respectfully,
Jeff_H is online now
post #14 of 34 Old 11-30-2009
JohnRPollard's Avatar
Consider also that a spade rudder can be "balanced" allowing for easier steering. A skeg mount generally can not....
There is a general misperception that skeg hung rudders cannot be balanced or semi-balanced. I've even heard some designers assert this, which is puzzling since examples to the contrary can be found in most yards.
Here's an example, a Morris 32/34 by Chuck Paine. Note the angled rudder stock:
JohnRPollard is offline
post #15 of 34 Old 11-30-2009
Originally Posted by Jeff_H View Post
...By the way, who ever said that a post hung rudder was cheaper was mistaken. The torque and moment resisting rudder posts on a post hung rudder are far more expensive to build than a strut and its gudgeons and pindles.
That is generally true of transom hung rudders -- whether they trail behind a skeg, long keel, or neither -- that pivot on pintles and gudgeons.
But many modern "skeg-hung" rudders are actually self-supporting post-hung rudders with the added protection (and expense) of a skeg.
post #16 of 34 Old 12-01-2009
johnshasteen's Avatar
Here's what little I know about spade rudder/bolton fin keel boats, other than I don't like them: The last time Paloma was at Southern Yachts for a bottom job, well over 1/2 of all the boats on the hard were spade rudder/fin keel beauties in for bent rudder repairs (the largest brand representation was big Benateaus) and one lone 30-footer was there for major separation of the hull/keel joint.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
johnshasteen is offline
post #17 of 34 Old 12-01-2009
GeorgeB's Avatar
In 2007, I raced a Nordic 44 (Bob Perry design) to Hawaii. The boat, a “racer-cruiser” had a skeg hung rudder. Pintle and gudgeon at the bottom. A bearing at the top of the rudder tube (below the quadrant) and an upper bearing above the quadrant whose bracket was through bolted at the transom and cockpit coaming. Boat was hauled and thoroughly inspected prior to the race. We were able to spinnaker reach starting on the second day with the reaching strut. This, plus the quartering seas gave us a lot of weather helm and consequentially, a lot of pressure on the rudder. Once we began to surf regularly, we had a fair amount of pressure on the rudder from the following seas. Around about the fourth day, the carriage bolts for the upper bearing bracket were chewing through and enlarging their holes giving the rudder shaft a lot of movement. The rudder shaft effectively pivoting on the middle bearing and the skeg flexing along with the rudder movement. We were able to effect a repair by patching a G-10 plate to the coaming and transom, using that as a new backing plate.
I tell the above anecdote merely to caution everyone that no rudder system is completely bullet proof. The Perry designed 44 is generally thought of as a “go anywhere” boat and it was a pleasure to sail it on this two thousand mile race. The skeg helped a lot and the boat tracked like it was on rails. The couple of times I found myself “sideways” on a wave, I was able to horse the helm around and get the boat pointing “downhill” again. The big downside of the skeg is the boat is a little slow in the tacks and isn’t very nimble when maneuvering in traffic.
GeorgeB is offline
post #18 of 34 Old 12-01-2009
sarafinadh's Avatar
A good resource on the basics of how rudders work and in what ways they differ from each other.
Rudder: Rugludallur
As far as the vulnerability issue, it seems like most obstacles would encounter the keel (that huge thing that hangs way down in the water AHEAD of the rudder, except for the times when going backwards, when they are almost all vulnerable) long before the rudder was in jeopardy. Not saying it couldn't happen, but seems like a longer shot than catching a log fish with a prop. (which I have done)
I have driven both and prefer a spade for handling (so long as I don't get the darn thing stuck backwards.... )
sara
ain't what ya do, it's the way that ya do it...
sarafinadh is offline
post #19 of 34 Old 10-10-2014
Re: Spade Rudders vs. Skeg Hung
Hello from Greece,
I am the happy owner of a first 35 from 1985.I thought of cutting the skeg and replace the rudder with a blade (spade) of a mum 36. I race my boat very often and I guess I would improve the speed and manouverability of the boat as an all moving surface is far better than the fin and rudder configuration. Using some simple cad programms as the compufoil or profili for example proved that the absence only from the hinge line and the cavity between the skeg and rudder improves the water flow 40% on a straight course and the first signs of flow delamination at 20 degrees with a speed of 5,5 kts. Not mentioning sailing on a spinnaker downwind. All the above make an easier steering and a faster boat.Anybody with a practical experience?
Safe winds in your sails,
nickhawk is offline
post #20 of 34 Old 10-11-2014
Wingnut
Personally i would go one further, and say outboard or transom hung rudder.
A really easy way to eliminate lots of problems, as well as to make selfsteering really simple.
Just last summer i saw two boats ( one hunter, one catalina) with F-ed up spade rudders.
The catalina builders apparently "forgot" to weld up the stainless flange, It held up for several years only being tacked together. Amazing.
the hunter simply bent the thing, rendering it unusable.
Luckily both boats were close to a haulout and were able to have the problem fixed.
both are very poorly built arrangments...
Dirtyfloats is offline
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Spade rudders vs blue water passage making deniseO30 General Discussion (sailing related) 40 09-11-2018 09:38 PM
Skeg Hung Rudder Question reignmaker Gear & Maintenance 5 05-18-2010 10:06 PM
Need advice on building spade rudders RobertKWFL Gear & Maintenance 4 05-07-2010 11:28 AM
Skeg hung rudders sailaway21 Sailboat Design and Construction 88 04-01-2008 02:17 PM
Fin/spade vs Modified fin skeg? orthomartin Boat Review and Purchase Forum 17 01-08-2007 06:44 PM
