Spade Rudders vs. Skeg Hung - Page 3 - SailNet Community
 1Likes
post #21 of 34 Old 10-11-2014
Omatako's Avatar
Re: Spade Rudders vs. Skeg Hung
Having a spade rudder knocked off by hitting something or tangling with nets etc. is probably a reason for one being nervous of it but I have a different reason for not wanting one.
To test this reason is (for me) simple. Take a broom, hold it in one hand at the very end of the handle and, keeping the handle horizontal, see how long you can hold it. I suspect this test will not take long.
Now hold it in one hand at the very end of the handle and hold it in the middle of the handle with the other hand and, keeping the handle horizontal, see how long you can hold it. You will almost certainly get bored before you get tired.
Now I know there are a lot of engineering formulea that will be postulated by the experts but for me, none of them surpass this simple test. A spade rudder places a vastly greater load on hulls, bearings etc. and simply cannot be as strong (weight for weight, size for size) as a skeg-hung rudder. At least, that's my opinion and I'm sticking to it.
Arthur C. Clarke
Omatako is offline
post #22 of 34 Old 10-11-2014
To test this reason is (for me) simple. Take a broom, ....
You have to go with what gives you the most peace of mind....
So.... I'm assuming then that in keeping with that philosophy you only fly on aircraft that still have wing struts???
Faster is offline
post #23 of 34 Old 10-11-2014
Super Moderator
Maine Sail's Avatar
And yet this skeg rudder survived, as a spade, to get the guy back to port when the skeg failed...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #24 of 34 Old 10-11-2014
Omatako,
Have you ever seen a skeg hung front fork on a bicycle?
It's all about design, engineering and manufacture. When done correctly either design works. And remember you can break anything, even a steel ball.
John
ccriders is offline
post #25 of 34 Old 10-11-2014
Omatako's Avatar
So, what can one say to that? Perhaps:
"One swallow does not a summer make". Or "Exceptions do nothing to disprove a rule"
Poor construction in anything will fail. That skeg looks like it was made from polyester putty.
Arthur C. Clarke
Omatako is offline
post #26 of 34 Old 10-11-2014
Omatako's Avatar
Originally Posted by ccriders View Post
Omatako,
John
So then the spade rudders that break are just poorly designed/engineered/made. I get it now. Thanks
Like I said, there will be a lot of formulea from the experts that . . . . . .
Good luck with your spade rudders.
Arthur C. Clarke
Omatako is offline
post #27 of 34 Old 10-12-2014
Coquina's Avatar
Bob Perry wrote a great article about how the spade rudder is superior in every way to the skeg-hung rudder. I wish I could find it, but the funniest thing was that for a fiberglass boat it is likely the rudder holding the skeg on, not vice versa.
Anyway at one time pilots were not about to fly an airplane without a lot of rigging to support the wings. I have flown a traditional airplane with flying wires between the wings that was as strong as a solid lump of steel and modern airplanes that manage without all the traditional bracing due to modern engineeing and materials too.
Joe Della Barba
Coquina
C&C 35 MK I
Coquina is offline
post #28 of 34 Old 10-13-2014
drosymor's Avatar
One possible solution to the argument of spades, skegs, wires and struts: full keel, transom hung rudder, unstayed masts. Nothing to worry about, provided you don't want to race.
drosymor is offline
post #29 of 34 Old 10-13-2014
Have a look at Beth and Evans website. They argue the superiority of spade rudder for a long distance cruising yacht much more elegantly than I could: see point number# 50
Boats.
noelex77 is offline
post #30 of 34 Old 10-13-2014
okawbow's Avatar
After sailing up and down the east coast for several thousand miles, in what seemed like one continuous crab and lobster pot field; I wouldn't try it in a boat with a spade rudder and exposed prop and shaft. Give me a full keel with the prop enclosed in a cut out.
Calls for help from boats caught in pots and nets were a daily occurrence, it seemed. I'll take the slower boat, every time if it means I don't have to worry about catching my rudder or prop on something, or knocking the rudder off in a minor grounding or collision.
In my Cheoy Lee 31, I simply sailed right through the crab and lobster pot fields without ever catching on anything. Motoring down the Tenn-Tom; I ran over several logs and trees with no damage to the rudder or prop, during flood conditions.
It just makes good sense to have a protected rudder and prop for long term cruising.
Chuck
Privateer 26 Schooner
okawbow is offline
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Spade rudders vs blue water passage making deniseO30 General Discussion (sailing related) 40 09-11-2018 09:38 PM
Skeg Hung Rudder Question reignmaker Gear & Maintenance 5 05-18-2010 10:06 PM
Need advice on building spade rudders RobertKWFL Gear & Maintenance 4 05-07-2010 11:28 AM
Skeg hung rudders sailaway21 Sailboat Design and Construction 88 04-01-2008 02:17 PM
Fin/spade vs Modified fin skeg? orthomartin Boat Review and Purchase Forum 17 01-08-2007 06:44 PM
