7
Re: Keel problems Islander Excalabur 26
man this thread was a looong time ago...but the info is still good...
alan what I meant was that the flex is an inherent part of the boats attiitude so to speak...now mine flexed like crazy in a lift sling...and I did nothing to it...mine was used in the delta and sf bay and did just fine
a member at the club came along with an IONA excalibur which were made later on and that boat did not flex as much...I remember he gave me the plans of the boat and showed me where he layed up glass and all...his boat was tuned even tighter
in any case look in your bilges...youll see the turns of the bilges on both access panels...the guy added layers in these two areas using strong woving...It has been soooo long I cant remember but I vaguely recall him and other excalibur owners and myself just living with this quirk
what you do NOT want to do is make this area so stiff and strong that therest of the boat develops stress cracks and or suffers from unwanted loads
the keel is not going anywhere as its not bolted but part of the hull like the cal 40 what you need to do if sailing the ocean or pounding against waves and such is to lightly reinforce the area so as to avoid stress cracking and failure...cant remember if there are floors or stringers in the bilge area but those could be reinforced as well
anyways
enjoy the boat
I miss mine...
ps....sailing the pacific would be an awesome sled ride for the excalibur...they excell as do their big brother the cal 40 off the wind...surfing
and yes they do surf if the wind is enough...
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
