Possible 27' Bluewater Boats - Page 2 - SailNet Community
 16Likes
post #11 of 64 Old 04-13-2011
Skipper Jer's Avatar
The $10K budget isn't going to get you a Nor'sea 27 on a trailer. Triple the 10K then you are in the game. Nor'sea's have circumnavigated.
Edit: Do you have at least a 3/4 ton truck to pull the boat?
Skipper Jer is online now
post #12 of 64 Old 04-13-2011
Cruiser2B's Avatar
I would think a pearson Triton or even an Alberg 30, which is trailerable, would work. These boats are plenty strong and most in your price range will need some TLC but it will allow you to do the boat the way you want. Albin Vega 27 seems like a stout boat as well. I personally have an Alberg 30 and I am speaking from the research I did when looking for the same type of boat. These were the boats recommended to me. Check out sailfar.net as well
I did alot of looking and reasearching about my Alberg for under 5k and sailed it home 200nm, yes she needs work but I think the deals are out there.
Cruiser2B is offline
post #13 of 64 Old 04-13-2011
Ericson 27 (one used to hold the record from San Fransisco to Japan)...I have mine for sale east coast (Rhode Island) ....
mikel1 is offline
post #14 of 64 Old 04-13-2011
bljones's Avatar
The 10K budget is the tough part, but two come to mind- Halman Horizon and
Westerly Centaur.
It's 5 o'clock somewhere:
bljones is offline
post #15 of 64 Old 04-13-2011
johnnyandjebus's Avatar
As already mentioned check out James Baldwin's site. I would add the contessa 26 to the list, but it is small, even for a 26' footer so it may not fit your needs
The Contessa Corner - A site for Contessa owners, sailors and dreamers.
I would argue that most if not all Carl Alberg designed boats 30 ft and smaller are candidates.
Carl Alberg's Yacht Designs
John
johnnyandjebus is offline
post #16 of 64 Old 04-13-2011
thehardaground's Avatar
Vancouver 27, but good luck finding one for under $10k
thehardaground is offline
post #17 of 64 Old 04-13-2011
Vancouver 25 : One person's offshore sailboat is another's NOT an offshore boat. Take a look at Mahina website, Atom voyages site, Westerly sailboats, and the book "Upgrading the offshore sailboat" and and other books about offshore, bluewater sailboats. And this unexpected entry; Hunter 27 offshore sailing??? - SailboatOwners.com
Re: Hunter 27 offshore sailing???
If any 27-footer could be safe in heavy seas then a Cherubini 27(Hunter of certain yrs)of a would be that boat. I doubt any 27 was built heavier. Still it was not ever meant as an offshore boat. There is the deck-stepped mast, the plastic windows, and a less than stout steering system.
sidney777 is offline
post #18 of 64 Old 04-13-2011
I know of Coronado 25's that have transited to Hawaii and further. There are many Catalina 27's that have done serious "blue water" work. If you are in the military and have limited time, I assume that you really mean to do coastal cruising. These boats can be had from $2500 to $10,000. BTW I have been offshore in storms in my Coronado 25 when we were viewing greento clear water out of the windows (we were essentially underwater)... but never blue. Above deck, I really did not notice the colors at the time... Greys.. Greygreen, Whites, foam... no blue.
CBSanford is offline
post #19 of 64 Old 04-13-2011
Send a message via Yahoo to landmineop
There is a Westerly Centaur in St. Pete with a deisel in your price range. Listed on sailboatlistings dot com. Not sure where you are but it may be worth a look.
landmineop is offline
post #20 of 64 Old 04-14-2011
Memopad's Avatar
I'm trying to sell my International Folkboat It's 26ft, a few have gone around the globe. My boat was an inboard but the engine has been removed. Now has an electric start outboard on the back. The boat is in good condition, the sails could use some work. I used them last summer and they work fine but new ones would be great. Also comes with a trailer. Asking $3500, I don't need two boats!
I'd use a lift or crane for getting the boat on the trailer. If you can weld, and afternoons work on the trailer would let you float it off easily. The rear supports are currently too high and aft to do that. A friend and myself raised to mast with a ginpole easy enough, could probably do without the pole i don't think it was helping. When we took the mast down he used the spin halyard, turned around the bowcleat, and lowered the mast while i walked it back. Took 5 minutes.
1978 Ranger 28 and a fleet of Mini 12's.
Ropes and rigging and splicing, oh my!
Memopad is offline
Best 30-36' boats for bluewater & liveaboard? kulokoo Boat Review and Purchase Forum 26 04-12-2015 10:59 AM
Bluewater/Not Bluewater which is it. BReach Cruising & Liveaboard Forum 9 10-26-2010 08:36 PM
Advice needed on bluewater capable boats Hmm Boat Review and Purchase Forum 17 03-23-2010 11:07 PM
Irwin 43 - Bluewater or not ??? Robby Barlow Boat Review and Purchase Forum 11 11-04-2007 08:14 AM
BLUEWATER? SAIL7NAV Boat Review and Purchase Forum 1 08-07-2002 05:43 AM
