welding my mast - Page 2 - SailNet Community
 2Likes
post #11 of 16 Old 02-23-2012
Welding aluminum will cause a slight warp in the material that is welded. (The weld will shrink the material) Additionally, there is a stress point adjacent to the weld that is a potential future failure. In a somewhat high stress area like you have I would not consider any welding. If all other areas of the mast are sound, as others have mentioned a riveted on patch would be the solution.
olddog60 likes this.
H and E is offline
post #12 of 16 Old 02-23-2012
Another vote for replacing the spar and not worrying about the next issue... no reason to believe the corrosion that allowed that to happen is isolated to that area..
Faster is offline
post #13 of 16 Old 02-23-2012
HANUMAN
RobGallagher's Avatar
I would have it checked out by a pro and be prepared for the worst. As others have mentioned, start looking on craigs, ebay, sailorman, etc. You might get lucky straight away or it might take a bit of hunting but something will come up.
RobGallagher is offline
post #14 of 16 Old 02-23-2012
overbored's Avatar
have you done this type of repair before that you are suggesting. do you know of any rigging shops that do it this way? No. I think its because the construction of all new aluminum masts and anyone that repairs aluminum masts does it by welding. riviting a repair will cause many stress points and you will get corrosion between the repaired parts that in the furture will be a problem. in fact thats may be what caused this problem in the first place, fasteners in the mast extrusion.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #15 of 16 Old 02-23-2012
olddog60's Avatar
Originally Posted by mcanty View Post
hello,
last season my spreader pulled off my mast in a storm and put a large hole in the mast. look at attached pictures.
I was wondering if anyone knew if this was fixable by welding a patch and droping the spreader below the hole. Or if i would have to buy a whole new mast tube. The mast is from a PY 23
Any thoughts please let me know,
Thanks,
Matt
NAHANT, MA
I am not going to pretend to be an expert,this guy is. Send him some quality photo's.
Julian Crisp
Owner - Sparman USA
Gainesville Florida
Tel: 352-222-4019
email: [email protected]
Home Page
olddog60 is offline
post #16 of 16 Old 02-23-2012
Welding aluminum WEAKENS it, depending on who's running the numbers and how conservative he wants to be, this can be as much as 50% loss within 1" of the heat-affected zone, though many will go with 15%. Down at the base, most of the load is compression, it may not matter that much. Hence the sleeve.
Steel is just the opposite. If 40 KSI material is welded, the rod is often in the 70 KSI range.
DonScribner is offline
repairing cracked mast with welding samgary Gear & Maintenance 10 12-12-2011 08:13 PM
HDPE Welding - ???? rikhall General Discussion (sailing related) 10 10-27-2011 08:39 AM
Stainless TIG Welding Equipment? matt2 Gear & Maintenance 5 03-25-2009 07:10 PM
Welding Cable KindOfBlue Gear & Maintenance 10 03-13-2009 05:11 PM
welding stainless exhaust box.... Rockter Gear & Maintenance 7 03-31-2008 04:48 PM
