How many thru-hulls do we really need... - SailNet Community
 4Likes
post #1 of 17 Old 06-28-2012 Thread Starter
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
Just reading Travelin Easy's thread on his thru hull access cure and it reminded me of a boat which has been on the hard here in Galesville, Md for a couple of years. I don't recognize what brand but it's a sailboat about 44 feet long. There are - get this - 26 (I'll spell it so you don't think it's a typo - twenty six - thru-hulls below the water line ON ONE SIDE. The other side has almost that many.
For the life of me I cannot come up with anywhere near that number of devices which might use that many.
Here's my count:
Fwd head: 2 (1 in 1 out)
Fwd lavatory: 1
Fwd shower: 1
Galley sink: 2 (1 out, 1 salt in)
Anchor hose down: 1
Air conditioning: 2 (assuming 2 ac units)
refrigeration: 1
Engine 2 (Maybe?)
Generator 1
Cockpit or other drains 4 (maybe?)
Aft head: 2 (1 in 1 out)
Aft lavatory: 1
Aft shower: 1
That's 21. I really can't think of any more. And what I thought of was probably ridiculous. And this boat has more than twice that many. Maybe a couple old redundant ones that have been capped off, no longer in use.
I've seen Hatterases (Hatteri?) with thru hull counts like that (still don't know where they all could go) but a sailboat?
Any speculation on what the rest of them could be for?????
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
post #2 of 17 Old 06-28-2012
Re: How many thru-hulls do we really need...
A 44 footer could have a lot more drains than that : my 31fter has 2 deck drains on each side athwartships, and two more in the cockpit.
MarkSF is offline
post #3 of 17 Old 06-28-2012 Thread Starter
And they exit below the waterline?
post #4 of 17 Old 06-28-2012
Barquito
Barquito's Avatar
Swiss Cheese 44. Nice lines, a little tender before the wind, and tastes good.
Valiant 32
Barquito is online now
post #5 of 17 Old 06-28-2012
Very much so, yes.
MarkSF is offline
post #6 of 17 Old 06-28-2012
KNOT KNOWN
Capt.aaron's Avatar
if you don't have an inboard you don't need any.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #7 of 17 Old 06-28-2012
So if you have an outboard you don't need a head, sinks, holding tank, deck and cockpit drains, and knotlog?
MarkSF is offline
post #8 of 17 Old 06-28-2012
KNOT KNOWN
Capt.aaron's Avatar
cockpit scuppers are above, just at my water line. Sink drain above water line. bilge out put above water line, head, is not plummed to the sea. I have no thru hulls below the water line since I pulled the engine 17 years ago, and I love it! Knot log.. I made a chip log I throw over the stern and count out the seconds if I don't belive my instincts.
post #9 of 17 Old 06-28-2012
Courtney the Dancer
jrd22's Avatar
Your list came up with more than I could have thought of Larry. That many thru hulls just seems absurd. With a little forethought many of them can be eliminated by combining supply thru hulls. We have too many in my opinion, 11, on a 40'. We eliminated two for deck scuppers, cut six openings for direct drains. If I was designing a new boat I'd have a salt water manifold that would supply everything and only require one thru hull, but you still need drains and those aren't so easy to combine due to logistics.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #10 of 17 Old 06-28-2012
travlin-easy's Avatar
I have six, three of which are inside the head. One of them doubles for the input for the toilet, and also has a "Y" fitting for the saltwater washdown pump. Another is for the head's sink drain, while the third is connected to the "Y" valve for the toilet. All are housed inside the cabinet beneath the head sink, where they are nearly impossible to reach.
Also have one for the galley sink drain, one for the air conditioner, and one for the engine. These are all readily accessible.
I cannot imagine a boat with 26 thru-hull fittings on each side.
Cheers,
Gary 8)
travlin-easy is offline
New thru hulls .. is this ok? smp Gear & Maintenance 27 04-11-2012 05:10 PM
More than 3 hulls? Ever been done? TintedChrome General Discussion (sailing related) 19 10-09-2010 07:09 PM
2.5 hulls planzman Boat Review and Purchase Forum 4 07-18-2008 11:20 AM
Through hulls drynoc Gear & Maintenance 5 08-14-2006 01:47 PM
Through-hulls? trecksail Gear & Maintenance 4 04-11-2006 01:28 PM
