new furling line on Old Seafurl - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 2 Old 01-07-2014 Thread Starter
Smile new furling line on Old Seafurl
Hi all,
My name is Greg and I am sailing on an old herreshoff bounty in Perth Western Australia. We have a problem with the 3250 furler (not a version 2), the furling line has finally given up the ghost and we cannot work out how to remove the old line. The articles on the forums talk about a hole underneath the bottom of the drum where the line would feed through and be knotted. However no amount of staring at the bottom of the drum has indicated the presence of such a hole. The line seems to terminate inside the drum itself, which is most inconvenient as I am sure hood would not have intended to have to take the whole furler apart to replace the curling line.
Any suggestions would be most greatfully received.
sojourn28004 is offline
post #2 of 2 Old 01-07-2014
Re: new furling line on Old Seafurl
This is the exploded diagram of the 3250. It looks pretty strait forward, but not on the bottom.
I you know how to splice I would recommend a length of 3/16 amsteel spliced onto a larger junk line where you hold it so you can get extra wraps on the drum. If not, then stick with 3/8 anything smaller can be hard to grab.
Greg
Stumble is offline
Replacing Furling Line on Hood Seafurl 810 arf145 Gear & Maintenance 50 10-13-2012 05:15 PM
SeaFurl 5 Replacement line MoonSailer Gear & Maintenance 2 12-22-2008 02:26 AM
Line on Hood Seafurl 3250 jr438234606 Gear & Maintenance 4 03-26-2008 12:23 PM
Roller Furling Line jr438234606 Gear & Maintenance 13 03-26-2008 12:43 AM
Broken Furling Line rrrr Gear & Maintenance 3 08-01-2001 03:20 PM
HTML code is Off
