Tartan piper 31 cutless bearing - SailNet Community
Introduce Yourself Welcome to the Sailnet.com - The world's largest online sailing community! Tell us about yourself so we can get to know you.
post #1 of 4 Old 01-25-2014 Thread Starter
Hi all
Need help. I can't find a cutless bearing for my tartan piper 31. It seems to be an odd size that I can't find online nor in catalogues. It's dimensions are as follows shaft 1"
Outside diameter 1.75"
Length. 4"
Any help would be greatly appreciated.
Thanks Noel
Nhcoyle is offline
post #2 of 4 Old 01-25-2014
FSMike's Avatar
Re: Tartan piper 31 cutless bearing
If you can find one with the proper ID and OD you can just hacksaw off any amount that's too long.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #3 of 4 Old 01-31-2014 Thread Starter
Thanks fsmike. The length was not an issue, it was the od for the one inch shaft that was causing the problem.
Solve by buying a smaller sized od, thanking the old cutless bearing and the new one to a machinist who will bore the old one to fit over the new one to make the correct 1 3/4" od
Thanks Noel
Nhcoyle is offline
post #4 of 4 Old 04-03-2014
There are companies that supply shaft bearings to any size to suit what you have, but these are composite not rubber. Maritex is one.
Kutter is offline
Tartan Piper 28 Stuffing Box Maintenance tommyp Tartan 4 03-26-2015 11:28 AM
34+ Cutless Bearing? Dave Montgomery C & C 2 05-02-2013 05:45 PM
Cutless Bearing Screws Redfish Pacific Seacraft 2 11-25-2008 01:44 AM
cutless bearing deniseO30 Gear & Maintenance 7 12-18-2007 06:40 PM
Replacing cutless bearing brak Gear & Maintenance 13 07-06-2007 04:33 AM
HTML code is Off
